Televison & Video Logo
D
Dale Fifield Posted on Feb 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung smart TV Model un46es6150fxza only stays on 30 seconds and shuts off and stays off until you turn it on again and it shuts down in 30 seconds every time.
I have done the hard reset etc. to no avail. I am thinking the problem may be on the power board, but hate to buy one without being more sure as it cost about 55 dollars. Any ideas? Thanks, Dale
Marvin
Level 3:
Top Expert:
  • Samsung Master 85,242 Answers
  • Posted on Feb 09, 2017
Marvin
Samsung Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29025423
Points
266281
You have a shorted circuit board. Which one will require troubleshooting and a repair manual for the TV
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jun 14, 2007
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Anonymous
  • Posted on Jul 06, 2007
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Anonymous
  • Posted on Apr 11, 2008
SOURCE: Viewsonic VX900 turns on for second then shuts off
I had to replace a fuse(F1) on the inverterboard of my VX900 to get it back to life as fuzzytek sugested.
It was replaced by a normal "flat" fuse (for cars). Had no clue about the value, so I tried with 0,5A first. It blew right away. Next value I had was 2A, and it worked! (It might be too small, and it might be too big, but I think it is better to usa a "large" fuse rather than no fuse at all. :)
Some pictures from my installation:
Robert Bloedel
  • 3 Answers
  • Posted on Mar 30, 2009
SOURCE: Tv shuts off
I had the same problem with my SONY TV shutting down and the green power light blinking 35-38 times before the set came back on. My RED Lamp Light never came on, but the problem is the LAMP. I spoke to SONY Support on the web and on the phone. All they wanted to do was set up a service call for me. I ordered a replacement bulb from SONY and it fixed the problem. This is a very easy replacement and they send the allen wrench you need to remove the old bulb and install the new bulb. Simple replacement Instructions are included in the box. Thanks to www.FIXYA.com I saved a very expensive service call.
Anonymous
  • Posted on Jun 26, 2009
SOURCE: Sony KDF-E55A20 shuts off for 30 seconds, then comes back on for 30 more
Do just as the others said pull out the bulb and clen the screens on top and bottom of bulb. BUT you can also prevent this from happening as soon the next time. You need to take off the back of your sony tv. On the right rear as you are looking at it there is a black blower on top that is on top of where your bulb fits in. you need a ninety degree phillups head screw driver. take the driver and take out the 3 screws... use a can of air to clean it out... You would not believe the holy hell dust stuck up in that blower!!!! Like I said, take the back of your tv off. If you are not sure where the bulb is once you get it off just turn it on. It's not going to hurt ya. If you are lazy about taking the blower off you can turn it on and shoot the can of air while the bulb is on but you are going to have to take the bulb out ALOT of times to get the dust out of the screens over and over until no more dust collects
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
2answers
My Samsung model pn64f8500afxza tuns on and off buy its self it makes a funny noise just before it happens
    Samsung PN64F8500AFXZA Issues with turning on - AVS Forum ' Home ...
    www.avsforum.com/.../1959809-samsung-pn64f8500afxza-issues-turnin...
    Apr 5, 2015 - 30 posts - ‎12 authors
    TV would turn off and on with no hesitation or delay. .... owners of the Samsung PN64F8500AFXZA model have experienced issues with turning ... Official Samsung PNXXE7000 - PNXXE8000 owners ...
    Aug 8, 2014
    Official Samsung UNxxES8000 Owner's Thread - Page 541
    Jul 7, 2014
    Official Samsung UNxxH7150 / UNxxH7100AF Owners ...
    Jun 10, 2014
    Samsung HW-F550 Soundbar
    Apr 7, 2013
    More results from www.avsforum.com
    Samsung PN60F8500 Crashing / Random Restart Issue ...
    ? 7:42
    https://www.youtube.com/watch?v=IM4fpFD-a3g
    Sep 24, 2013 - Uploaded by ryandev00
    Samsung PN60F8500 Crashing / Random Restart Issue .... Do it have that directional buzz like last year model. ... times it will happen just like yours, even turning off and on non stop 10 seconds apart. ... Samsung PN64F8500: 1080p 600Hz 3D Smart Plasma HDTV - Duration: 1:29. mytvtoday 6,782 views.
    Samsung TV Keeps turning off and on. - Forums - CNET
    CNETHello, If my LN-T4053H TV is off for a long period of time (hour or more, it seems), then when I turn it on, it repeatedly turns off and on by itself for a m... ... This problem is all over forums on the internet, various TV models. Some people re-solder ...Missing: pn64f8500afxza
    Samsung PNF8500 review - CNET
    www.cnet.com > Home Entertainment > TVs
    CNET
    Rating: 4 - ‎Review by David Katzmaier
    May 1, 2013 - Samsung's best-performing TV ever, the PNF8500 series pushes the plasma picture ... Samsung PN64F8500, 64 inches ...... After 25 days of owing a 2014model Samsung tv it randomly started shutting off and on, this was a ...
    Are there still capacitor problems with Samsung TVs?
    www.practical-home-theater-guide.com/are-there-still-capacitor-problem...
    I am experiencing the same thing with my TV turning itself on and off (very annoying).... I had same problem with my samsung smart tv model un40f6300af power off and on. It would ..... PN64F8500 gone a few months after Samsung warranty.
    TV Is Turning Off And On By Itself (Power Cycling)
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 28, 2013 - PN50C550G1F TV Is Turning Off And On By Itself (Power Cycling). If your TV is powering off by itself then powering back on you may need to ...Missing: pn64f8500afxza
    Support - Plasma TV PN64F8500AF ' Samsung TVs
    www.samsung.com > ... > TVs > Plasma TV
    Samsung ElectronicsTurn the Smart Touch Control over so the back cover is facing up. Placing one or two... Placing one or two fingers in the groove, gently pull the back cover off. 3.
    Amazon.com: Samsung PN64F8500 64-Inch 1080p 600Hz ...
    www.amazon.com/Samsung-PN64F8500.../B00BCPH...
    Amazon.com, Inc.
    Rating: 4.4 - ‎407 reviews
    Samsung PN64F8500 64-Inch 1080p 600Hz 3D Smart Plasma HDTV (2013 Model) ....With Samsung's 3D converter, turn 2D viewing into 3D for an amazing ... Stand is amodel of strength and an eye-catching complement to your Smart TV. .... Off axis viewing is spectacular and it's bright room performance is top notch, ...
    Amazon.com: Customer Reviews: Samsung PN64F8500 64 ...
    Amazon.com, Inc.Samsung PN64F8500 64-Inch 1080p 600Hz 3D Smart Plasma HDTV (2013 Model) ....I will admit defeat and will turn off ARC and use an optical cable instead in ... I had my eye on all the Samsung TVs as the 2012 models were released.
    My Samsung model pn64f8500afxza tuns on and off buy its ...
    www.fixya.com/.../t26046430-samsung_model_pn64f8500afxza_tuns_o...
    28 mins ago - My Samsung model pn64f8500afxza cycle turns on and off it also makes a noise before it cycle a on and off, what part do I need to fix this.
    Searches related to Samsung model pn64f8500afxza turns on and off
    samsung pn60f8500
    samsung pn60f8500 manual
    samsung tv power cycling
    samsung capacitor settlement
    samsung capacitor settlement 2015
    samsung tv wont turn on
    samsung tv repair
    samsung tv warranty
    1 2 3 4 5 6 7 8 9 10 Next
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
Samsung UN46ES6500FXZA turns off by itself
I can not acces my Facebook deos not recognize or mail or password,how I can restart t.v to install and to atarte again please help me , thank you
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
2answers
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
