Question about Janome Sewing Machines
MC 7000 Er 3 (Dealer suggested; M/B, Fuse, or Servo issue) assumed the code 3 means that Servo/Sensor 3 is at issue (zig-zag control) Servo 3 (Blue connector) appears to be the same ohm check as Servo 2 (Black connector) (array test , pin1 -2, 1-3, 1-4 ... 2-3, 2-4 ....) Servo 3 sensor led has 1 Volt with Diode tester which matches Servo 2 sensor (sensors are clean and typically only fail if the sending led is blown) Mother board Servo controllers all have the same readings to ground on all pins with no overheating indicators P/S Fuses all check out ... now suspecting that there may be a P/S issue ... does anyone have the voltage levels that should be on the P/S cable to the motherboard?
  • bxdobs Jul 27, 2009
    Totally disassembled the machine and found a transistor on the Power Supply board that had overheatted and basically pulled the solder pads off the board as well as disconnect itself from the circuit. I have repaired the Power supply and partially reverse engineered it. Suspect the Failure may have damaged the Mother board as this fix still hasn't cleared the Error code
    15 pin Power Supply connector:
    1) Sensor Left
    2) Sensor Middle
    3) Sensor Right (wheel)
    4) Analog 120 Hz (40 Volt Full Wave Bridge output)
    5-6) 24.2 V (from Emitter of TR1 ... Base is 24.2 V from Zener ... Collector is Filtered 40 Volt)
    7-8) Analog GND (split from Digital GND on the Motherboard)
    9-10) Digital GND (split from Analog GND on Mother board)
    11-12) 5 V (from P/S Regulator)
    13) Main Motor Control (input)
    14-15) 40 V (Filtered supply used for Servo controllers)
    There is a 10 pin encapsulated device on the mother board where the output of this transistor is connected to so wondering if there is some logic inside this that is testing the Power supply ... if the supply is out of spec perhaps this device is causing the error?
  • bxdobs Aug 05, 2009
    Janome has confirmed the boards for this machine are no longer available as it is too old plus have no technical information on this machine. I am certain I can fix this issue all I need is confirmation of the Transformer Secondary Voltage OR the Servo Voltage pins 14-15 of the Power Supply Board. I am reading + 40 Volts but thinking this may be High ... expecting a voltage somewhere between 25-40 Volts. If the transformer primary windings started shorting that would bump the secondary voltage and explain the Transistor failure from overheating due to having to drop more voltage. Its a long shot but if the question goes unanswered and the voltage is too high there is the potential to damage the servo controllers and or the servo's.
SOURCE: Husqvarna 2000 sl no zig zag movement
You might try oiling where the needlebar slides side to side (and everywhere else). More than likely it needs to be freed up somewhere.  Also there is a small piece called the cam follower that can pop off. Look inside near the cams and the piece with a finger that follows the cams may need to be reattached. They do come loose sometimes. Good luck.
Posted on Oct 18, 2007
bargainbox
  • 1388 Answers
SOURCE: Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Posted on Feb 01, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
Does anyone know what kind of motor, Servo or clutch, is in a HUSQVARNA huskylock 1002LCD? Also does it zig zag?
The information I found about your machine indicates it is a serger, not a sewing machine. A serger does not zig-zag.
Apr 18, 2017 | Husqvarna Sewing Machines
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
Kenmore ultra stitch 6 Model 13402
If the machine is not zig zagging when you select zig zag it will mean the selector finger needs adjusting which is a shop job
May 26, 2014 | Sewing Machines
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Someone gave me a singer 403. I put in the zig zag attchment but it still sews only straight. What am I not doing??
Of course, you have to push the zig zag adjusment lever from the 1 position to one of the zig zag positions, 2-5. Also, the zig zag disc must be inserted. Take of the top of the machine (two screws to loosen the attachment and lift off the top), and you can see a steel connecting piece called the pitman and it should move back and forth when zig zag is engaged. If it isn't, maybe something is gummed up as has been suggested.
Jul 20, 2012 | Singer Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
I have a 1970's era sewing machine (an almost antique) & I cannot change the control for zig zag or any other design - the control seems to be frozen. This machine gets very little usage...
I would suggest to take it to a sewing machine repair shop, a sewing machine is like a car once in awhile they need to be serviced, checking for loose or broken parts, getting greased & oiled, is the life of the machine, it help the machine last even longer.
Sep 13, 2011 | Husqvarna Sewing Machines
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Nov 22, 2010 | Brother XR-65t Mechanical Sewing Machine
No "Zig" to my "Zag"
I Love the support Brother gives!
Here's what Brother says about the Zig zag issue.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faqh/000000/000000/000018/faqh000018_000.html?reg=us&lang=en&c=ca&prod=hf_xl5130eus&page=FaqEndPage
your manual (download)
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl5130eus.html?reg=us&c=ca&lang=en&prod=hf_xl5130eus
Sep 25, 2008 | Brother XL-5130 Mechanical Sewing Machine
Feb 26, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
87 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
