Question about Amcor ALD12000E Portable Air Conditioner
WE HAVE AN AMCOR ALD 12000E AND THE CONDENSATION HAS BECOME A PROBLEM. IT WILL NOT RUN OFF THE MOISTURE, THE RESERVOIR FILLS AND UNIT SHUTS OFF WITHIN HOURS. EMPTY PAN AND IT REFILLS AGAIN WITHIN HOURS? ANY SUGGESTIONS - OR A REPAIR SERVICE IN VENTURA COUNTY CA
    President:
  • 1,124 Answers
That can be quite normal.. Depending on how much humidity there is in the air..
Posted on Jul 22, 2009
Amcor amb 12000e, starts to cool and after a few minutes the unit "shudders" and starts to heat. Not sure why, please advise. Thank you
You are almost out of freon... call a service co... DO NOT run this unit until you get it charged.
Jun 19, 2017 | Amcor Heating & Cooling
No Power
All rechargeable batteries die if left to sit uncharged for extended periods of time. If you can replace the battery, do so.
Jun 30, 2014 | Amcor ALD12000E Portable Air Conditioner
No Power.
Yes, It is highly possible that the unit had a leak and did loose it';s charge while in storage.
Override temperture setting on Amcor Amc-12000e portable Air Conditioner
Actually there is no way to do what you want because the unit is designed to operate when the inside temperature allows the heat exchanger to function so that it will condense the liquid refrigerant into a gas.
As far as using it in the winter to dehumidify this same applies. If it is to cold then the gas won't be able to condense back into a liquid. If I were you I would buy a portable dehumidifier but remember that if the temperature is to low it won't work.
Good luck
Marty
Mar 01, 2014 | Amcor PCMB-12000E Portable Air Conditioner
I have an AMCOR ALTL1200E, fan works, cold air comes out when the compressor turns on BUT after 5 minutes compresor turns OFF, then after 5 minutes again it turns on, what is wrong, thanks
Sounds like the unit is cycling off on a high head pressure (condenser coil too hot). When the condenser cools, the automatic switch resets. The unit cuts off again when the condenser heats up again. Clean the condenser coil, and clear out any debris (bird's nest, lint etc.)
Aug 30, 2013 | Amcor ALTL-12000E Portable Air Conditioner
When i turn it on it shuts off and the power button flashes red
Sounds like the condensation pan is full and the float switch is shutting the unit down. I just encountered this issue, there is a small pump that usually prevents the pan from filling up by pumping the condensate over the condensor and evaporating it, either the pump has failed or the humidity is too high and it can't keep up.
May 24, 2012 | Amcor ALTL-12000E Portable Air Conditioner
After years of perfect operation the water reservoir tank needs to be emptied every few hours. Is is almost a gallon of water each time. The normal time was always every other day ...at most once a...
12k BTUs will condense a gallon an hour easily, sounds like the problem is with a probable self-evaporating portion of the condenser. If so either the inner workings of that unit are dirty/malfunctioning or the exhaust duct is not getting proper airflow. If you're mechanically inclined I'd recommend pulling the unit apart and cleaning the condenser parts. If not perhaps try attaching a permanent drain hose to the drain plug. Definitely check the exhaust duct either way.
Sep 22, 2011 | Amcor ALTL-12000E Portable Air Conditioner
There is no drain pipe for the unit I have. It has a cap on the back but no hold, how does the condensation.
Self Evaporating Technology - During the cooling process, water is extracted from the air into the unit. Most of this water is then recycled and used to cool the unit and make it run more efficiently. Approximately 65 to 70% of water condensed is evaporated out with the exhaust air, reducing the hassle of emptying the water tank constantly. This unit has a built-in water tank (not removable) with a drain outlet, and a water tube. When the tank fills, the compressor stops operating and the power light will flash. This indicates that the tank should be emptied.
Jul 21, 2011 | Amcor ALTL-12000E Portable Air Conditioner
Amcor 12000-E air conditioner will not emit cold air. all filters are clear and hose is vented to outside. I'm about to boil
Hi, I'm new here but have the same model. Is your A/C new? Is your "Mode" set to "Cool" rather than "Fan"? Is the temperature set below room temperature? If not it will just run as fan. Lastly is your water reservoir full? Probably not the problem as the unit will shut off. Looks like you posted this a couple weeks ago, hope you figured it out.
Tim
May 07, 2009 | Amcor ALTL-12000E Portable Air Conditioner
Amcor ALD12000E Portable Air Conditioner Logo
202 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
