the recording on all sony mini disc are really great (automatic adjustment) unless you are trying to add alot of bass....(then you must ajust manual to keep from being distorted)..here is the manual go to page 32 and follow the info for manual control sony http://www.manualsmania.com/download.php?link=40d75264244158c71e79f5db93e49684275c43f8
hope this is helpful feel free to rate
pretty simple, turn it on for radio, hold mode utton for 2-3 seconds to switch to speaker mode. if u turn it off and turn it again on, it will always start in a radio mode! thats all
To Pair: 1. Turn on your Bluetooth speaker/headphones (slide switch to BT) 2.
Light should turn on Blue. If not, plug speaker into USB
connector and light will turn Red to indicate it's charging. 3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT. 4. Enter pairing code (passcode): 0000 or you can try: 1234
I turned it on, and pressed the video/live recording button that was next to the trash/delete button. That is a whole other menu. After pressing the video/live recording button, I just went up to the first selection, "Program." That takes it off the basic/Q-Mode, which opens additonal options, like ISO and Date Stamp on/off. So basically:
1) Turn on, having the camera on picture taking mode, not review picture mode.
2) Press Video/Live Recording button.
3) Go to first option, called "Program"
4) In this mode, many other options are available, and there will be smaller icons.
This unit is too old and too basic to handle 16x speed. However, there is a firmware update for this model DVD/VCR to record on 8x.
All you have to do is call the toll-free number in your manual and request it. They will send you an update disc.
Here is the basic procedure after you receive the update disc:
1. Turn on your TV and your combo unit. The tray should be closed. The unit must be in DVD mode.
2. Quickly press the sequence CM Skip, 6, 5, 4 (This will switch it into firmware update mode. The tray will eject automatically.)
3. Insert the disc and push the tray back in. 4. The update will begin. It will take approx. 2-3 minutes. It will tell you when it is complete and eject the tray.
5. When it is done, remove the disc, but DO NOT close the tray. It will go back in later. Turn the power off.
6. Wait a few minutes and when the tray goes back in wait about another 10 seconds and then you may turn the unit back on.
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Setting the clock 1. Press SETUP in no disc mode or full stop mode,MENU screen appears on the TV screen. 2. Using v select SETUP MENU, then press ENTER or >, BASIC SETUP is highlighted. 3. Using v to select “Set Clock ”, then press ENTER or >, “Set Clock Setup ”screen appears. 4. Press</>/^/v repeatedly (or numeric buttons) to set the date and time. 5. Press > to select “Done”or“Cancel ”, and then press ENTER , BASIC SETUP returns. 6. To exit, press SETUP. 7. Press POWER to turn off the unit, the clock appears on the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
1. create a new folder (wherever)
2. highlight all the documents
3. right-click and select "cut"
4. go to folder, right-click and select "paste"
pretty basic stuff.
