Memory ram can anyone tell me the maximum amount of ram i can install om my motherboard asrock k7s8xe. i have been told 1 gb of 400 ddr is the max . i have a cpu of 3200 running at 400 frequency. can i use 2 x 1gb of 333 ddr instead. which is best.
  • adzzz101 Jul 22, 2009
    Hi thanks for your advise. this is very helpfull i will keep my 2 x 1gb of ddr 333. i upgraded the cpu and my os vista kept resetting but i istalled a bigger power unit and this seems to have solved the problem.
  • Computers & ... Master
  • 5,660 Answers
Since your AMD Athlon XP 3200+ has a Frequency Rate of 2.2GHz, (2200MHz), and has a Front Side Bus of 400MHz, you can use Two - 1GB sticks of PC2700. (DDR at 333MHz)
(It's the Barton Core model. Has an L2 cache of 512KB, an 11X multiplier, uses 1.65 volts, and has an FSB of 400MHz. Part Number AXDA3200DKV4E)
OR, you can use One stick of PC3200. (DDR at 400MHz)
I know you know this, but I wanted to explain why.
It's because the SIS 748 chipset has memory limitations.
I advise using Two sticks of PC2700. (DDR at 333MHz) In this case, more ram amount is better, and the drop in frequency rate is minimal.
Put the ram in Slots 1 and 2. Slot 1, is the Slot closest to the processor.
Here is ASRock Support, and the page for the K7S8E,
http://www.asrock.com/mb/overview.asp?Model=K7S8XE
(Just copy and paste the above into your address bar, then press the Enter key)
If you want the Motherboard Manual, go up to the left side under -> Overview and Specifications. Click on Manual.
The manual is in PDF file form. Your computer has Windows on it, and Adobe Reader. Adobe Reader uses PDF files.
Give it time after you click on the server link you want. (ASIA, Europe, USA)
It may take up to 30 seconds, before you will see the first page. Wait until it has fully downloaded, before looking through it.
If you want to know how to save it to your computer, (You can also burn it off to CD disk), come back, and post your question in an additional comment.
Would appreciate it if you would rate my solution.
Posted on Jul 22, 2009
  • 73 Answers
The ASRock K7S8X Motherboards takes the PC2100/2700/3200 DDR SDRAM DIMMs .
You can upgrade to a maximum of 1.0 GB (PC3200) / 2.0 GB (PC2700) / 3.0 GB (PC2100) Memory, the system has 3 sockets to install Memory, already with 0 MB (removable) standard Memory installed. For best Motherboards performance use the maximum amount of allowed Memory per slot for your Motherboards.
  • 202 Answers
Doubt if you would notice much difference between 333 and 400 ddr.
here are the memory specs on the mb:
- DDR non-ECC, un-buffered memory
- DDR400, Max. capacity of system memory: 1GB (FSB 400/333 MHz)*
- DDR333, Max. capacity of system memory: 2GB (FSB 400/333/266/200 MHz)
- DDR266/200, Max. capacity of system memory: 3GB (FSB 333/266/200 MHz)
*According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
  • 60 Answers
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
http://www.asrock.com/mb/VIA/P4VM8/
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Is gigabyte-81915me-c motherboard support 1 gb ddr2 RAM? The Ram is 1 GB DDR2 800Mhz.
    This is the RAM specs for this motherboard.
    Memory
    1. Type: Dual Channel DDR 400/333
    2. Max capacity: 2 GB
    3. DIMM slots: 2
    * Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
    Jun 21, 2011 | Gigabyte GA-8I915ME-G Motherboard
    I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
    Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
    Hope this is what you are looking for,
    Cheers,
    Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
    Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
    What is the hidhest ram i can use on a celeron 2.6
    Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
    Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
    Sep 28, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Aug 26, 2009 | ASUS PSCH-L Motherboard
    I have upgraded my k7s8xe with athlon xp 3200 cpu. I have adjusted the jumpers to fsb 200 & installed 1gb ddr 400 ram. system keeps rebooting os vista enterprise. any suggestions. also can i install 2...
    First of all, if your FSB is set to 200mhz, the system will not support DDR400. "CPU at FSB 200MHz mode, it will NOT support DDR400". The FSB will have to be either 333 or 400mhz in order to utilize DDR400. Only 1GB of DDR400 is supported. As to your rebooting issue, could be because of these incompatibilities and/or you did not properly seat the heatsink/fan on the new CPU, which also means you might not have properly applied thermal compound or might have no applied it at all. All the compatibility information for this motherboard can be found at: http://www.asrock.com/mb/overview.asp?Model=K7S8XE
    Jul 19, 2009 | Computers & Internet
    Buying RAM to my ASRock(845GV R5.0) Motherboard ?
    it can support up to 2GB ram maximum FSB 533/400MHz,
    Memory Supported RAM Technology: SDRAM, DDR SDRAM
    RAM ( Max ): 0 MB / 2 GB (max)
    Supported RAM Speed: PC2100, PC1600, PC100, PC133
    Aug 10, 2008 | Asrock P4I45GV R5 Motherboard
    Recommended memory for p4i45gv R5.0
    IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
    Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
    Computers & Internet Logo
    169 people viewed this question
    David Payne
    David Payne
