Question about Hayward SUPERPUMP 2.0 HP, 115/230V
Two hot wires one ground
I had a hsyward superpump and it went out. I then changed the capsitor and worked for a while. Next it started to chip in and out before it stopped completly. I bought a new motor and nothing happened. I have takin the motor back and they test it on 110v and it worked. I have sinced tested my wires the black was 120v, white 120v and the ground. What's next??
  • kareem_brown Jul 23, 2009
    Boyh the black and the white wires are coming off the switch in the box. Both have 120v when tested agianstthe ground wire. When I test them agianst each other I get 0volts. whats next?? When I test both to gether agianst the ground I still get 120v.
    President:
  • 1,714 Answers
I'm wondering...you say 120v on white, I want you to check 'between' the white and black for 120 volts. I think you may have 240 volts. Check it...
Posted on Jul 22, 2009
  • Craig Butler
    Craig Butler Jul 23, 2009
    This indicates the white neutral wire is open going back to your power source. The black is the 'hot' and it's feeding through the motor and back on the white wire, that's why you read 120 volts to ground on the white. But it is 'open' and not getting back to the source. Trace the white back and check all the connections all the way back to your source voltage coming in.
  • Craig Butler
    One more thing. You said the black and the white come from the switch. The white wire is never ''switched' (it should feed around the switch, only black is switched). Make sure that the switch does not switch or 'open' the white wire. With the switch turned on, you should see 120 volts when testing across the black to white.
Dash gauges stopped working except oil and battery gauges
Year make and model. Newer vehicles have a couple hot wires and a couple grounds. But for the most part the IP(instrument panel) is run threw data wires. These data wires run to a logic chip in the IP. These chips can just one or two things, or all. Older cars are simpler. Most problems happen at the plug. Unplugging it plugging it back in, could fix the problem.
Aug 25, 2015 | Cars & Trucks
Bike gives a click as if it has a dead battery but the battery is charged and starts other bikes fine
If the batteries good its probably a bad ground. make sure the hot and negative wires are good from the battery AND where they end up. The ground wire usually grounds to the frame somewhere, trace the ENTIRE wire!
Mar 31, 2014 | 2003 Yamaha YZF 600 R thunder cat
Aldl
You have a defective battery.
Jul 13, 2013 | Oldsmobile Cutlass Supreme Cars & Trucks
White whire
if 220 2 hots and a ground 120 volt black to L1 white to L2 see side of motor for wiring must change to 120 volt
Feb 17, 2013 | Hayward SUPERPUMP 2.0 HP, 115/230V
I am replacing a 230V single speed AO Smith with a hayward super pump 230V two speed of proper size. Out of the super pump are two purple wires, a black wire and the green ground wire. The superpump has...
It sounds like you need to purchase a 2-speed switch for the rear of your super pump. With your current set-up, you will only be able to connect either a low speed, or a high speed and not both.
If you confiirm this via my e-mail, I can further guide you as to what you need to do next. If you just want to connect the high speed for now I can also help with that. By the way, are both purple wires solid in color, or does one have a black stripe on it?
If this post has helped you, please take the time to vote positively for me after reading this.
Thanks,
Adam
Oct 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
We can't figure out which is positive and which is common.
If I understand correctly, you are trying to identify wires inside a 3-way switch box?
Common wire is the wire that connects to dark-colored screw. Before taking wires off 3-way switch, it is customary to mark the common wire.
If you already have switch out and can't remember which wire went to dark colored screw I suggest you put old switch back in place and try the wires on different screws until both 3-way switches work correctly. Don't worry, circuit simply doesn't work if wires are placed on wrong screw.
You may also be trying to identify Hot and Neutral wires.
Hot is usually black, Neutral is usually white.
Here's how to test. Separate wires. Turn on power. Use ordinary tester. Tape tester leads to wood sticks so hands are away from power. Test each wire to bare ground wire. Tester lights up on Hot wire. Next, test Hot wire to each wire (except ground). Tester lights up on Neutral.
Oct 02, 2010 | Pass & Seymour #T603WV 600W White 3WY...
It the line terminal the hot (i.e. Black ) wire
If I read your question as "Is the black wire the 'hot' line" then yes, it would be, IF your line leads are wired to code and we are talking about 115V.
Oct 14, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
May 15, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Hayward SUPERPUMP 2.0 HP, 115/230V Logo
317 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
