Question about Kitchen Ranges
Accidentally pressed the lock button, not the clean button. Now none of the buttons work except the timer. Can't clean. Tried the breaker switch. it turned everything off,but came back on with the lock button lit. HELP!
  • dianaspaldin Jul 22, 2009
    my phone rang, and you expired my session. The comments you made were on the right track, but I explained that none of the buttons work. Not clear, not clean. Please help.
    President:
  • 1,714 Answers
Isn't there a 'clear/stop' button?
Posted on Jul 22, 2009
  • Craig Butler
    Craig Butler Jul 22, 2009
    You were talking to someone else. I just made a comment to you. .
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
My frigidaire oven door says locked and I cannot unlock it.
Reset the unit at the household circuit breaker for about 10-15 minutes. Then retry the unit. If no changes occur contact a professional technician, sounds like the door latch and/or control board need repairs.
Aug 02, 2012 | Frigidaire Ovens
Hi, the machine seems to have hung. there is a CL symbol in the timer slot and no button is functioning including the power button. i had to switch the machine off from the mains.
hi.
i am fairly sure that CL in the timer window means that the child lock has been turned on.
this locks all buttons to ensure that children cannot accidentally start the machine or change settings.
to turn it on or off, press and hold the prewash button for three seconds.
hope this works.
if not, please feel free to ask for more details
Mar 31, 2011 | LG WM-2277HW Front Load Washer
My uniden bc80xlt handheld scanner has lost all button functions. The radio still scans and picks up frequency broadcasts, but NONE of the buttons work. What is going on here?I have no" manual" function, I...
Sounds like you may have accidentally pressed the "LOCK" button. If there's a "key" icon showing, press the LOCK button at the bottom left of your keyboard, and hold it in until the icon disappears. In case you need it, here is a link to the operating manual for your scanner:
http://www.uniden.com/pdf/BC80XLTom.pdf
Nov 22, 2009 | Uniden BC80XLT Handheld Scanner
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Oven is locked
press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Range oven door
try holding the door switch closed and press cancel. that usualy takes care of it. if that doesnt work send your model number out and this will help.
Sep 26, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
