Central A/C unit has a leak
We live on the second floor of a condo. The central air conditioner unit is mounted in a hallway closet. Apparently there is a leak because the tenant in the apartment downstairs has a wet stain in her ceiling just below our unit.It appears to be a slow leak and the slightly damp ceiling stain is slowly spreading.The area in the closet where the unit is is completely dry.Do you have any suggestions as to what the problem may be and how to solve it?
    President:
  • 1,124 Answers
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Posted on Jul 22, 2009
    Problem Solver:
  • 9 Answers
In the closet is a drip pan for condensation off your evaporator coil and a drain, i would say your drain is clogged, pull the cover off the airhandler and force air to blow the debri out , i use a small air compressor and hose to force out the debri. hopefully you're not dealing with cast iron pipes.
Posted on Jan 15, 2012
Why would unit be leaking water on the inside unit
If it is leaking on the inside (coil) it usually is a sign the condensate drain is plugged causing overflow, or the coil is freezing up inside and when its off it thaws the ice and melts down the center of the coil and onto the floor,
Jul 21, 2014 | Ruud Central System Air Conditioner
Air Conditioner problems
Your fan or more likely the fan motor mounts have failed and the fan is out of balance. Replace your motor mounts before the motor fails too and the repair cost doubles.
Jul 07, 2013 | Heating & Cooling
Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Aug 14, 2012 | Heating & Cooling
I live in a condo and have a central air/heating unit in my kitchen/hallway area. This past week, right before it turns on, I hear a very loud bang. It sounds like it is coming from inside the unit. It...
might need to change the filter could be pulling it aganst the frame when turning on hard to say, have it checked out if you are worried it is dangerious.
Aug 30, 2010 | Weather King Heating & Cooling
A/c unit leaking underneath onto floor, puddle in the hall!
from the evaporator coil, the drain maybe clog. clean the unit to fix it.
Jun 11, 2009 | Ruud Central System Air Conditioner
Have new central h/a--installed last year. Problem--during the hottest part of the day (85+ degrees), it is about 80 inside with the air going. Windows are shut, blinds barely open in lr (closed in rest of...
somebody is full of you know what. If it can't satisfy the space the unit is not working properly or the new unit was not the some capacity. If the air handler is in the attic i would look for loose duct work pulling hot air from the attic. Do you know a neighber that has the same house/condo as you if so compare model#s ck024 the # 024 is the capacity the 024 would be a 2 ton 030 would be 2 1/2ton 12,000 btu's equals 1 ton
Jun 04, 2009 | Heating & Cooling
Unit leaking
leakage from my central air unit from drain pan, please help
Apr 29, 2009 | Whirlwind FH-778 Air Conditioner
Unbalanced cooling or heating
You need to balance the system. It's a matter of adjusting the dampers or registers so that you have a little less air flow near the T-stat and more to the other end of the house. Likely you have a return vent near the T-stat. That return draws air to it and likewise the T-stat. If you are getting a lot of air out of the registers on that end of the house damper them to force more air to the other end of the house. Do not close them entirely though. You may have to play with it a little to get it right. I hope this helps. Please remember to rate Fixya rate me.
Feb 23, 2009 | Ruud Central System Air Conditioner
Amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Jan 31, 2009 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
