SOURCE: Emerson 900 Watt Microwave MW8991SB glass
For more help from
Emerson visit
here or get
help using your appliance at 1-800-898-9020. Get help locating an
authorized servicer or parts at 1-800-695-0098.
Emerson parts are
distributed by Fox
International
and their number is 800-321-6993. Or you might try
e-mailing [email protected]
Many Emerson microwave
owner's manuals are available for free download here.
Even though
yours may not be there, there might be one close enough to help you .
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: where can i take a 'sparking' 900 watt emerson
Contact Emerson. Call the number on the back. More than likely they will tell you there is no servicer in your area and ask you to cut the cord and mail it back to them and they will send you a new one. I don't know if they'll do this for out-of-warranty microwaves as well.
SOURCE: Emerson MW8999SB 900-Watt Microwave replacement plate
From what I could find, it should be 10 1/2 inches in overall diameter.
meowpfttpftt
SOURCE: I have lost the manual
You can get the manual on the link below.
http://dl.owneriq.net/b/b16a006c-69da-da14-617d-c870555087f3.pdf
Good Luck
SOURCE: emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
