SOURCE: WATTS
The output power is 1000W and that's near the high end for a consumer microwave. Hope this helps.
Please write back with more details if you need further help.
We do appreciate your very thoughtful rating of our answer.
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
