Question about Panasonic GigaRange KX-TG5432 Cordless Phone
Panasonic KX-TG2583. How do I change the time?
Panasonic KX-TG2583. How do I change the time? Also..how do I change the amount of rings before answere phone answers?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Posted on Jul 30, 2009
How do I leave a message for my answering machine
Ask the service provider
Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
change amount rings panasonic kx tg7643 Answering ...
Jan 12, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
How do I change the amount of rings before it goes into VM?
I think you would have to access the firmware via a terminal so if you know the quad ie.192.168.x.x 'x' being any number between 0-255 includeing zero and hitting connect then you should be able to access this stuff via the firmware menu.
Mar 04, 2015 | Panasonic KX DT343-B Digital phone - Black
I would like to change the ring numbers on my Panasonic KX T 7730 from two to four or five because sometimes it's impposible to get to the phone that fast
You need to enter the programming mode from the default EXTN usually 20 or 21 and change the timings of the ring counts, normally shown in seconds, adjust to 30 secs which should give you the amount of rings you need if not just go back and adjust the ringing counter seconds up until you find the length of time that suits your needs.
Aug 31, 2013 | Panasonic KX-T7730 Corded Phone
How can we change the ringtone on Panasonic KX-T7730 phone?
You don't. Panasonic analog system phones have one ring tone. You can change the cadence (single double or triple) ring from outside calls, but not the tone.
Carl
Oct 26, 2011 | Panasonic KX-T7730 Corded Phone
How can I change the number of times the phone rings before the voice mail answers? Model # KX-TG4022
The amount of rings before a call goes to voicemail is setup on the network itself and not the phone. Some mobile providers won't let you modify it and others will depending on your region. You would have to call your mobile provider for the availability of the option and the procedures. Sometimes you dial a number to change it other times it can only be changed manually by the provider.
Jul 15, 2011 | Panasonic Cell Phones
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Dec 02, 2009 | Panasonic KX-T7633 Corded Phone
Manule for cord less phone model kx-tg5422
http://www.retrevo.com/support/Panasonic-KX-TG2583-Telephones-manual/id/2914dj790/t/2/
Please find the user guide /manual for the phone.
Thanks
Have a nice day and please donot forget to rate this.
Mar 20, 2009 | Panasonic KX TG2583S Cordless Phone...
Panasonic KX-TG2343 cordless phone
I'm not sure about changing the amount of rings, but you can turn down the ringer.
1. Press the "menu" key, just below the "off" key.
2. Press the down arrow until you reach "Ringer setting," and then select this by pressing the key just below the screen on the right side (directly above "off" key) .
3. "Ringer volume" appears on the screen - select this the same way as you selected "Ringer setting."
4. Use the arrow keys to change the volume, and then press "Save" by pressing the same key you used to select.
Dec 09, 2008 | Panasonic KX-TG2343 Cordless Phone
Panasonic GigaRange KX-TG5432 Cordless Phone Logo
1,234 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
