Question about Dometic Rooftop RV Air Conditioner
I replaced the fan motor in a coleman rv 13,500 a/c and wired the same but the motor is running in reverse then stops after a minute.
    President:
  • 1,124 Answers
If you are 100% sure the wiring is correct,,
It might be the capasitor..
Posted on Jul 22, 2009
Coleman ac roof rv model #6702a808 wiring to fan motor#1468a3069 diagram.
Request the fan motor wiring diagram directly from Coleman.
Jul 31, 2017 | Coleman Heating & Cooling
Ac works fine when fan is on low but fan cuts off after a couple of minutes on high
Bad fan motor. Multi-speed motors have a set of windings for each speed. Your high speed is bad so the only solution is to replace the complete motor. When motors are going bad they will over heat and kick out on the heat safety. As it cools back down it will start again for a short time again until it gets hot again.
Jul 12, 2015 | Coleman Dometic Duotherm Rv Air...
Coleman Rooftop AC fan stops after 7 or 8 minutes of running. Will turn on again after about 10 minutes on its own.
Remove green (fan run) wire from thermostat, and connect to red wire (power) and see if fan runs, and if it will stay running. That will by-pass thermostat to see if it is problem. If it continues to run, thermostat is problem. If that doesn't cure it, I'd remove cover up top and with power off at circuit breaker, blow compressed air in to motor air holes to make sure it's getting proper air for cooling, as well look for small plastic plug on housing where oil can be added ( few drops) to lubricate motor. Leave cover off and try fan to see if that may help. If at all possible, a clamp on amp meter will confirm if motor or relay is at fault if none of these suggestions help. If amp draw at motor too much, motor may be seizing when warmed up from running. test draw when first started and after running for amount of time that it usually quits, and if noticeable difference, motor is seizing and needs replace. You can also test amp draw at main 120v feed wiring with unit just in fan mode.
Sep 13, 2012 | Coleman Heating & Cooling
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
We have a Coleman roof unit a/c on our RV. We are going to be replacing it and we're not sure what the btu's are. We are thinking 13,500. The model no. is 6759-707. Can anyone tell us what the btu's are...
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers
Jun 08, 2010 | Coleman Mach 15 Air Conditioner
RV ac fan runs backwards (blows out air on top of RV.) Runs correctly sometimes but after it satisfies and clicks off when it kicks back on, it runs backwards. The only thing that will turn it back around...
Hi, this is strange as I have never heard of this either!!! The capacitor is located by the motor and sometimes clamped to the motor. They can be the shape of a very small can, oval 3" tall with 2 leads on top with wires coming off the terminals. It could be chrome in color, or made of hard plastic. It may have 3 terminals on top, with several spade connectors on it.When you find it, mark all wires and draw a picture or you will not remember how it hooked up.Try and get the same one. Keep me posted and I can help if you need more. Strange thing going on here??
Shastalaker7
Dec 22, 2009 | Coleman Mach III Air Conditioner
Coleman RV Roof AC Fan Issues
It sounds like you have a bad fan capacitor.
You might try replacing it, they don't cost very much.
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
Replacement fan motor for coleman mach3..need wiring diagrm
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
GO TO rvcomfort.com
You can get Service Support or Email address and Phone numbers.
Apr 14, 2009 | Coleman Mach III Air Conditioner
RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
197 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
