SOURCE: toyota yaris brakes how do you bleed the brakes on a toyota yaris
have someone pump the pedal and hold it, then you work from the right rear, left rear, right front, left front, while the person pumps and holds several times at each wheel.
SOURCE: 1994 toyota fuel pump relay
Fuel pump relay is in the engine compartment left side fuse block
SOURCE: i cant find the fuel pump relay in a 94 toyota
relay should be inside the hood next to engine there is a fuse box cover stated what relay are uses.
SOURCE: I have a 2010 toyota
Probably that you have an emmissions issue...
If the light stays on after you start the car...
consult your dealership... your car is under warranty so whatever they do is free anyways...
There are 3 relays in the glove box. All 3 are behind the plastic cover in the upper left corner of the glove box. The relay to the fuel pump is the one to the far left.
