Question about Garden
Champion r434 mower. How do you start it? - Garden
    President:
  • 1,129 Answers
There is a primer bulb on the side of the engine it looks like a little black round nipple pushin on it 3 or 4 times then try make sure the throttle is set just back a little from fast.
Posted on Jul 22, 2009
Can you use a champion spark plug rdj7y in 6.5 silver series lawn boy mower
Anthony you can use any kind of spark plug brand as long as its the same size. Sometimes they have a longer sparking element and this will catch on the piston. Just be careful.
Sep 10, 2013 | Champion International Lawn Mower Champion...
My mower, a Craftsman model 917.378941, uses this spark plug. But the plug gets loose, and the mower backfires and blows the plug out. Now I can't get the plug to tighten on the mower. Help?
You mean the threads are stripped off, and you can't get to even start threading? They make a plug threading tool kit that cuts new threads, you glue in this insert, and hope it holds. Or else, get it threaded out and run it with a different plug. I would find a lawn mower shop that has done this, or a machine shop that works on 4 wheelers, etc. Hope this helps.
Jun 24, 2010 | Champion International Champion& Small...
CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
Apr 14, 2010 | Garden
Champion petrol mower ran low on fuel - was
I suspect that there may have been dirt at the bottom of the tank or possibly water. Try changing the fuel filter but first clean the tank and refill with clean petrol
Oct 12, 2009 | Champion Jockstrap and Abdominal Supporter
MANUAL FOR cHAMPION r434 where can I get a copy of the manual please
Try freemanuals.com. They have lots of choices.
Sep 10, 2009 | Garden
Mower won't start
Check the terminal from the solenoid to the start switch. It is corroded either there or at the switch. Lightly sand with fine sandpaper and reassemble.
Best regards, --W/D--
Aug 02, 2009 | Champion International Champion& Small...
Riding mower won't start from key switch
Do you have power to the switch? This is the only thing that jumps out at me, as you already did the right things.
Check that. I bet it'll get you going!
Regards, --W/D-- Feel free to rate my answer.
Jul 24, 2009 | Champion International Champion& Small...
My riding lawn mower won't start. New battery (cables & connections are clean), new filter, plug, rebuilt carb. It's getting spark but won't start? I cleaned the magneto and flywheel. Any other ideas?
Spray starting fluid into the air box if it starts and dies out there is a fuel delivery problem if the mower has a petcock fuel shut of valve disconnect the fuel line after the petcock and hold a container under the hose turn on the valve to ensure gas flow to carb if there is no petcock valve I would still check the line to carb make sure gas flows through the hose to carb.
Jul 23, 2009 | Champion International Champion& Small...
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Mar 20, 2009 | Champion International Champion& Small...
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
