Question about Imperial IFS40 Deep Fryer
Temp does not follow what its set at
Need to set the thermostate to 250 degress to get it to stay at 350 the temp is about 100 degrees off?
    Scholar:
  • 81 Answers
Pull the thermostat knob off. get a small flaslight and shine it into the stem for the knob. You will see a small screw down inside. turn the screw counterclockwise to adjust the temp to the dial. A little bit( 1/16th of a turn) at a time
Posted on Jul 25, 2009
2003 yukonxl tempture gadges asking up
Had similar problem. Air temp.was 95 degress or more and I was running the ac setting still. Temp gauge went up to 240 or 250. I increased te rpms while sitting still and temp came down. Once I starting moving temp came down to normal operating limit.
Jun 06, 2012 | 2003 GMC Yukon XL
Deart All: Thanks alot for your kind answer but do you had been ever heard about a maintenance guide or a fixing manual for the Hitachi RUA-30 AT3S package units . Actually the compressor did not worked...
Dear friend!
I think, you keep cool mode and temp setting above 30 degree C. Definately it will not work. If you need cool or heat follow this step and if still problem write there.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Jan 10, 2011 | Heating & Cooling
The thermostate now reads 112 degrees and will not go below 97 this causes the cooling unit to stay on at all times even though the true room temp is 71 degrees. What is wrong with this thing? It appears...
Hello,Locate and move the thremostat sensor(bulb) to a different location as it is near something on the unit that is 112*f.It needs to sample return/intake air temp.
Sep 18, 2010 | Amcor Portable Air Conditioner...
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
GE Oven MODEL J KP27WOP2 WG - WILL NOT HOLD TEMP
You can re-calibrate the oven as follows;
press BAKE pad.
select temp of 500 degress or more.
immediately PRESS and HOLD the BAKE pad until "00" appears.
Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
When fimished press the Clear/Off pad.
Mar 15, 2009 | GE JTP15 Electric Single Oven
Fryer will only go to 250 degrees
Need to calibrate the thermostate,or replace it
Mar 12, 2009 | Imperial IFS40 Deep Fryer
A.O. Smith Water Heater Problems
someone has messed with the differential setting - so the water heats to correct temp but cools too low before coming on. get book -easy fix
Oct 26, 2008 | Water Heaters
Inacurate temp
The follow suggestions apply if you are at sea level, or a bit above. If you are in the mountains, you'll have to compensate for altitude issues. You need an accurate thermometer to be spot on. One way is to use an electronic thermometer. Another is to set the oven to 217 degrees, insert a small pan of water into the oven, with a metal tray or pie tin on a lower rack to catch spills and see if it eventually boils. If the water didn't boil, you can adjust the temperature upward in  5 degree steps (see your owner's manual for details). If you've lost your manual, you may be able to go on-line and get a pdf copy of your manual.If the water does boil, you know your oven is accurate within 5 degrees. You can then proceed to re-do the experiment at 212 degrees, if you wish. Then you may use the data to adjust the oven temperature.
Dec 03, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Imperial IFS40 Deep Fryer Logo
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
Dan Webster
Dan Webster
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
