Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Whirlpool Imperial Electric Dryer wont heat up
Same thing as the others...the dryer starts but does not heat up
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 22, 2009
My gas whirlpool duet dryer was working fine...one load finished (it dried fine). I then put it another load and now the heating element will not come on. By the way they appliances are one week old. This is the 8th load I have run with not problems until today. What gives?
Posted on Jan 03, 2010
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
My whirlpool imperial electric dryer wont heat up
It's either the fuse, heating element, thermal cut-off or thermostat
May 21, 2012 | Whirlpool Dryers
What would cause no hot air when drying on a whirlpool imperial gas dryer ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Whirlpool Dryers
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
I have a Whirlpool Imperial Gas Dryer (Model:LGN2000.JQ0) where the heat will intermittantly go on or stay off. Can you let me know what would cause that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Whirlpool GGQ8831L Gas Dryer
My dryer wont start i have power 220volt comming out of the outlet but nothing
heatman101
Sep 06, 2010 | Whirlpool WED5300S Electric Dryer
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
332 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
