Question about IBM ThinkPad T43 Notebook
Power cord not working
My power cord is plugged in to the wall and computer and it was working about 5 min. ago and now it's not. Do I need a new cord? or could it be the connection on the computer?
  • draykyn2 May 11, 2010
    A few things to check first: 1. Have you tried a new outlet? 2. Does the connection feel loose when you plug in the power cord to the back of the laptop? 3. Do you have a battery installed? 4. If yes, has it been charging the battery before it went out today? There are a few problems that can cause this issue. If the connection is loose between the back of the laptop and the power cable, that could mean that the DC Jack needs to be repaired.(this is inside the laptop and it is the hole you are plugging the power cord into). If it is not loose, you could try this without the battery installed: unplug the power cord from the laptop; press and hold the power button on the laptop for about 15 seconds; plug in the power cord (w/o the battery); Does the laptop power on now? .
  • 126 Answers
Let the power cord/adaptor cool down a bit, then reattach it. It will work.
I suffered this problem with an IBM adaptor on a T41 machine. It started working again after 1 week and is still working fine. Ofcourse it was no use since i had already purchased a brand new adaptor.
Posted on Jul 22, 2009
  • 453 Answers
Try unpluggin the power cord and check with battery.
Check whether battery is charging with the power chord on.
Try with a different wall socket.
If this does not help.
Try with a different power chord of the same kind and check whether it works.
If yes, the power chord is the ussue. Best would be to replace it.
else
Try your power chord in a laptop similar kind and check whether the other laptop works fine.
Try juggling the power cord and check whether it gives supply.If yes then check for AC adapter for any damages or cuts. If any is found the contact manufacturer for replacement.
else Main board is the issue.
But before this I would request you to go to the website and check for Updated BIOS and updates for chipset driver.
If any is available then download and install.
Check with your AC adapter if it works, Good, else I would request you to contact the manufacturer for a Main board issue.
They would replace the main board if under warranty.
Why going off after 5-10 min black screen
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 04, 2014 | Gateway 24" Widescreen Flat Panel TFT LCD...
Screen goes black or pixelates
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
My wii will not turn on
Hi,Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Thanks and good luck
Jun 03, 2010 | Nintendo Wii Console
Tower switch dose not turn on.i took out power wire from the wall plug when i went to trip 5 weeks ago
Make sure the power cord is securly plugged into the Power Supply Unit in the back of the PC and also in the wall outlet. Look for a switch by the cord plug on the pc that will have a straight line and a circle on it. Make sure it's switched to the ON position (straight line). Try and turn on your pc.
If this does not work still, try a different AC outlet on another wall or in another room. Also try a different power cord for the PC. If none of these work and your machine will still not start up or you don't hear any fans going when you press the button, it might be a bad Power Supply Unit (PSU). I have seen PSU's blow out just by plugging or unplugging the power cord because it can create a spark. If you have a bad PSU, you will need to contact someone local to replace it or you can take your unit to a Best Buy or local computer store and have them give you a price on a new PSU.
Dec 14, 2009 | Sony VAIO VGC-RB42G PC Desktop
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
Wii plugged into power but wont turn on
Check your AC adapter with voltmeter if you have.Try unplug device wait30 min and plug it again.If this not help may you need new ACadapter.Look here.
Nov 03, 2009 | Nintendo Wii Console
It will not turn on
Unplug the AC adapter from power cord wait 30 min and plug it again.If this not help you may need new AC adapter.
Oct 19, 2009 | Nintendo Wii Console
Wii will not work. Not even turn on. Not even red light or anything just black.
Try to unplug the AC adapter from the power cord and wait 30 min.Then plug it again.If this not help may the AC adapter is defective.
Oct 16, 2009 | Nintendo Wii Console
My Wii console won't turn on.
First:
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
Third:
Fourth:
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
IBM ThinkPad T43 Notebook Logo
201 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
