Question about Denon AVR 3808Ci Receiver
Denon Surround Receiver Mod.: AVR 3808CI Issue: My Denon Surround Receiver Mod.: AVR 3808CI is connected to a Charter Cable box (Mod.: Scientific Atlanta 4250HDC), an LG HD DVD (Mod.: BH100), and a 52? Samsung TV (Mod.: HL-P5063). This system configuration is about 10 to 12 months old. I?m having two problems I believe are related to the Denon Receiver. 1 ? The video drops out for 5 to 8 seconds while a program. This occurred for 3 to 4 months from Dec.2008 thru April 2009 then began to behave OK. 2 ? Recently for a month or so, when changing the channel from, say, Ch 47 to Ch50, the audio would drop out at Ch 50 and would continue for several higher channels, sometimes as high as I would go. If I stopped at Ch 50 and cycled back to Ch 49, 48, and 47, the audio would resume. I tried several possible investigative solutions. I used the respective RC?s for each item. a. Relative to problem 1 - When the video was dropping out, I used the TV RC, during the 5 second video drop-out period to change volume and observed the normal volume control indication on the screen. I also observed, when there was no video, the lamp would glow inside the back cover thinking the screen was completing shutting down. The lamp continued to glow. This problem has not reoccurred. b. Relative to problem 2 - When changing the input between HDMI using the RC from HDMI position 3 (TV) to position 1 (DVD) then back to position 3, while sitting on Ch 50, the volume would resume. But when cycling back to Ch 47, the volume would again drop out. Then again moving back thru Ch?s 48 thru 50, the volume would resume. c. Relative to problem 2 - When the TV is operating, while viewing Ch 47 and the sound cuts, if I power off the Denon Rec., wait 3 to 5 seconds, then power the Denon Receiver back on (it is automatically set to come on at Ch 47, the volume resumes. When then advancing up to Ch 50, volume is on thru Ch 49 but cuts out at Ch 50. d. Relative to problem 2 - I also tried using the DVD, set to HDMI position 1 via the RC, the volume sometimes works and sometimes not.
  • 2,359 Answers
Beside the all the units you mentioned is there any more eletrical items plug in the same circuit?
All home 120V AC outlet is 20 amps, I would ran any extention cord for the 52" Samsung TV.....just to make sure it's not a power related problem.
If you has a APC UPS AC backup unit for you computer system......move it over to your AV setup and see does it beep (line voltage drop/brown out) .
If you have a DVM or plan old meter. Check the 120V out voltage. It can range from 110 to 120 depend on time of day and the power draw in your surrounding area..
In the TV setting there is a commerical audio level automatic adjustment. Check it out. It will cut the HIGH volume sound during commerical.
If this is my AVsystem,
I would ran a 14 or 16 AWG wire to link everything together and ground the end of the wire to the center screw on the electrical plate.
This will completely rule out grounding problem.
If all else fail,check the warrenty on the TV set and call for service.
My bet is on the commerical audio adjust volume reduction setting. Flip though the setup screen and turn it on.
I will check this post later. Please keep me up to day.
Posted on Jul 22, 2009
Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Mar 05, 2010 | Denon AVR-1908
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
How do I set up outdoor speakers? I currently have them set on Surround B, but do not seem to be able to play them
Fined in owner's manual section about MULTI ZONE CONNECTION AND OPERATION. page 68. If you don't have a manual, download it from here : http://www.usa.denon.com/AVR-3808CI-OM-E_404A.pdf
Nov 08, 2009 | Denon AVR 3808Ci Receiver
Hi with my denon avr 1908 can i run video through HDMI cable and sound trough Coaxial cable so i can get 5.1 surround from my sky HD box
you can get 5.1 using HDMI connection.
other wise in the set up you can configure the denon to not use the hdmi audio and configure that input to use coaxial or optical all digital inputs allow for 5.1 once all connections are made on the front of the unit find the input mode button and select auto
Jun 30, 2009 | Denon AVR-1907 Receiver
I have a Denon AVR-3808CI A/V receiver, a Samsung HL67A750 DLP TV, a Samsung BD-P1600 Blu-ray player, and a Motorola HDPVR for the cable signal. I have connected the Blu-ray player and HDPVR to the Denon...
You will have to disable one or the other. Most likely the source because not all disk"s will be recorded the same. If a disk was transfered from film to digital poorly, this will show up as a grainy look on your tv, not much you can do about that. I would set your tv the best possible and go with that, also if your tv is capable of 24fps use that setting.tweaktv.com can help you with your tv setting. Use Progressive Mode on you blueray and your dvd also.
Apr 24, 2009 | Denon AVR 3808Ci Receiver
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Jan 08, 2009 | Denon AVR588 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Denon AVR 3808Ci Receiver Logo
250 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
