Question about Cell Phones
My LG KG300 bluetooth is not working it enables but do not receive any file and not send to other mobile
I have a bluetooth dongle. problem is i can only send files from my mobile phone (bluetooth enabled) to my pc and not vice versa. the bluetooth dongle (connected to my pc) can't search for other bluetooth...
You need to give more info, I'm afraid.
What type of phone do you have? What OS does it run? What kind of OS does your PC have? Did your adapter come with software? You say you can send files from your phone to your PC, but then you say that the PC doesn't the phone (?????!)
Since I don't have any clarification, here's some things you can try:
- Try shutting down and re-starting both your devices with the adapter still in. Try taking the adapater out, re-starting and then plugging the adapter in.
- Re-install or update the software for your adapter. If you decide to re-install, make sure you remove all th eold files completely. If it's plug and play, you can use device manager (assuming you have Windows) to find better software.
- Make sure your phone has the proper permissions set to receive files from your adapter. Since I do not know your phone model, try to google it.
- Try opening Bluetooth Devices in Control Panel. Click on Options and make sure you've enabled the PC to accept files from your mobile.
Bluetooth isn't two way automatic communication. Both devices that are using Bluetooth to communicate must individually have permissions set for the receiving of files from each device it connects to. You can send files all day long, but if the device youre sending to isnt set up to receive, it obviously won't work. Make sure you've enabled it in both the PC and the mobile.
Good luck.
Mar 21, 2011 | Computers & Internet
Blackberry curve 8520 unable to receive files transfered from other Mobile device through bluetooth. But able to transfer data to other mobiles through blue tooth
My Blackberry curve 8520 can send data via bluetooth but it unable to receive data from another bluetooth enabled device. please send me solution.
Jun 17, 2010 | RIM Holster For BlackBerry Curve 8520
Please send me LG KG300 pc suite please
hi
just get the driver and pc sync
from here
http://xpvistatricks.blogspot.com/2009/09/lg-mobiles-pc-suit-links.html
never forget to vote me
thanks in advance
Sep 03, 2009 | LG KG300 Cellular Phone
My new samsung e1410 mobile have probleam with bluetooth .I can't able to send file via bluetooth to any other mobile.where other mobile able to send them that files from their mobiles but I can't able to...
Your phone might not support blue tooth file transfer. Call your service provider and ask, they should be able to tell you. Also the file you are trying to receive/send might be to big
Jun 29, 2009 | Samsung Cell Phones
Lg kg300 mobile reset
Go to the Settings Menu of your handset. There you will find an option to Reset your phone to factory default. "Reset Factory Settings or Restore Settings"
Apr 24, 2009 | LG KG300 Cellular Phone
I want lgmobile pc suite kg300
please send me LG KG300 pc suite please
Mar 02, 2009 | LG KG300 Cellular Phone
My bluetooth and usb cable not working
LG:KU970:My bluetooth not working,Cannot send out file but can received via mobile phone
Dec 15, 2008 | LG Shine KE970 Cellular Phone
Lg phone KG300
i have a problem with bluetooth of lg kg300 that data is not share with another bluetooth mobile . please solve this problem that my bluetooth is continue for sharing the data . thanks
Jun 16, 2008 | LG KG220 Cellular Phone
LG KG300 cellular phone
i forgot my LG KG 300 phone pin code
can u tell ho w i solve the prob
Jan 31, 2008 | LG KG800 Cellular Phone
LG Prada receiving via bluetooth troubleshoot
There is a restriction in the JPG ratio/pixel size on the Prada.
You need to first get your photos on to your computer and check the size of them is 640 x 480 and that they are standard .jpg
Make sure any file you send is not 'in use' I.E. you don't have the file open on your computer - open files/in use files cannot be sent.
Also, after every download to the phone, you need to move the jpeg file to the external memory as the phone itself can only cope with a few files at a time before registering as full.
Dec 30, 2007 | LG Prada KE850 Cellular Phone
Cell Phones Logo
270 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
