Question about Sprint Hitachi P300 Cellular Phone
Cannot get video on to my Akai screen . I also have Sky TV and Mikomi DVD Player. I am an 89 years old War Pensioner in sheltered accommodation and a hopeless technical ham. Rolyjohn Moris.ham
Need replacement remote control 5.1 Akai HHT-006
This company or eBay
AKAI TV Remote Controls ' AKAI Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/AKAI/Remote-Controls/
  1. Cached
ReplacementRemotes.com offers AKAI remote controls for sale online including remote controls for TV, DVD Player, TV/DVD Combo and many more. Missing: 5.1
Akai TV Remote Controls ' eBay
www.ebay.com > ... > Akai TV Remote Controls
  1. Cached
  2. Similar
AKAI KC02-A2 OEM Replacement TV Remote (LCT3701AD,LCT3201TD,LCT2701AD) ... Akai Samsung TV Remote Control Replacement BP59-00069A. $9.99. Missing: 5.1
replacement remote control 5 1 Akai HHT 006 Google Search
Apr 14, 2017 | Akai Televison & Video
The foron screen dont show dvd - only show a blue screen. It seem to a conflict in the system as it react very slow Is it possibel to reset the system?
HELP! DVD player/video mode blue screen ONLY! - DVD Talk Forum
forum.dvdtalk.com > DVD Discussions > DVD & Home Theater Gear
Jul 26, 2005 - Windowless vans do NOT have candy, only. When I click on the set up menu, all I see is that blue screen and the green VIDEO in the ...Missing: foron
Help please--DVD/VCR combo blue screen - The Mac Resource Page
forums.macresource.com/read.php?1,653657
Jan 23, 2009 - 19 posts - ‎4 authors
I hope this does not mean that the video channel on the player is ... TV and see where you have the inputs from the DVD/VCR plugged in, if you don't know. .... viewing andonly turn on the JVC when I want to use it for a movie.Missing: foron
Sky HD box just showing blue screen...?! ' AVForums
www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
Feb 03, 2016 | Cars & Trucks
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Flat screen TV only has volume. When we turn it on, the screen is light gray with a darker gray stripe in the middle. TV is only three years old! The dvd which is part of the TV stopped working in the...
Sunds like a tv issue. I would try to connect a dvd player or vcr to it to see if that works to eliminate the service provider first, if it still doesnt work its the tv.
Nov 20, 2010 | Akai Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
TV turns itself off after turning on. TV screen goes black.
Based on what I have read AKAI has reoccurring problems with power supply and bad DVD sound. The problem you have is caused by the DVD player trying to start. Never leave a disk in when you shut it off or you will have the same symptom you are describing.
Oct 07, 2008 | Akai LCT2721AD 27 in. LCD Television
Dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Snowy screen playing dvd's
1.Check audio/video RCA jack cables
2.check S-video(if you use S-video cables)
3.check with another dvd player to get normal picture on your tv system. if picture is normal in this process. then problem with your old dvd player.
4.if same problem occurs in other dvd player. then problem with your television. external audio/video processing circuits
5.if the tv is ok. then the problem with your old Dvd player audio.video converting circuits
6. if can be rectified by authorised service engineers
7.Contact service engineer. as there is no recitification process from user part
Dec 15, 2007 | Hitachi 43FDX01B TV
No Audio
The yellow, red & white terminals are composite out (old RCA connectors). Yellow is video. Red is right side audio out (line). White is left side audio out (line). You can connect them directly to any TV that accepts composite input. (i.e. Match the colors).
Feb 25, 2007 | Akai DVPS760 DVD Player
Sprint Hitachi P300 Cellular Phone Logo
Top Sprint Cell Phones Experts
Dan Shibata
Dan Shibata
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
