Question about Maytag CWG3600A Gas Single Oven
My burner is not lighting. The igniter is glowing red hot. It seems like the gas valve is not allowing gas to burner. Could this still be the igniter? is there a sensor not telling the gas valve the igniter is hot?? Thanks, Keith
    President:
  • 1,714 Answers
The flame sensor is not allowing the gas valve to operate. The gas valve could be bad, but probably the flame sensor. If you can use a meter, we can check to see which one it is.
Posted on Jul 22, 2009
I have a 5 burner gas range and cooktop one burner on cooktop won't start
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 12, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Oven starts and stops
Apr 02, 2014 | Kenmore Ovens
Ignitor work but burner do not lite
Feb 16, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
    The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
    Oct 11, 2009 | Viking Ovens
    My Amana gas oven won't heat up gas smell strong
    Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
    Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
    Burner not lighting but igniter is glowing red hot.
    The flame sensor is not activating the gas valve. Check or change sensor.
    Jul 22, 2009 | Maytag CWG3100A Gas Single Oven
    The lower oven ignighter does not glow
    I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
    FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
    Jul 20, 2009 | GE JGRP17 Gas Single Oven
    Maytag CWG3600A Gas Single Oven Logo
    280 people viewed this question
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
