Question about Canon Pixma iP2600 Photo InkJet Printer
Paper not feeding right
Not feedint paper throught correctly, it pulls it down to much on the right side and makes it sideways and then it will not print.
    Problem Solver:
  • 6 Answers
You need to take all of the paper out then fix the paper so it is all aligned then place the paper back into the paper holder still all aligned this should then prinbt properly
Posted on Jul 22, 2009
Mp499 The paper tries to go thru but only one side pulls it and it goes sideways and gets jammed.
The feed wheels on the one side are either worn out or have some scrap paper stuck on them. Take a good look , after removing the paper tray, if it has one , inside the machine. It might be possible to turn the machine around and see into it from behind, if there is an access door on the back.
Aug 02, 2014 | Canon Office Equipment & Supplies
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Hp 2610 paper jams on print command. Paper pulls sideways.
find the paper feed rollers and clean them. they get slick and one side will catch quicker and pull the paper side ways.
Aug 12, 2010 | HP Photosmart 2610 All-In-One InkJet...
Mine does the same thing--feeds sideways into the printer--pulling more to the right--then jams up. I turned it upside and shook and shook. Turned it sideways and shook and shook. I cleaned the rollers...
The guide rollers are smooth. this oftyenj occurs due to impregnated ink. I see you have cleaned it ( with alcohol?) which is a good start.
Use one of those green ploastic scourers and roughen lightly the guide wheels and the platten ( large roller) I would also suggest trying a different grade and brand of paper in the unit. Some papers just wont feed as they are designed for lasers rather than inkjets etc and vice versa.
please rate our help to keep the service online
Aug 17, 2009 | Office Equipment & Supplies
My printer is feeding more than one page at a time my printer is cannon 3000
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results?
May 23, 2009 | Office Equipment & Supplies
Epson CX5000 Paper will not load. Tries to but says paper jam even when there is no paper jammed. Blank pages will go through during reset but not otherwise.
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results? Once we have this information we will try to fix the unit through email support.
Apr 29, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Calculator paper roll change, How to?
feed paper throught bottom to top hold down paper feed botton
Jan 26, 2009 | Sharp EL-1801P Calculator
Paper getting stuck
the reason the paper is going in sideways is because one feed roller has more pressure than the other
try cleaning the rollers with alcohol and cotton cloth
If that does not work remove the paper tray t
take your fingers and see if the feed rollers turn freely or turn in only one direction( some rollers are half moon and only turn a half turn)
Just try to make sure that the roller that is not working is in the same position and turns the same as the one that does feed properly
Jan 04, 2009 | Office Equipment & Supplies
Paper is pulled into printer unevenly and then jams
Hi Jocase, there is most likely a foreign object in the paper path of your machine. Often tipping it on it's back will dislodge the offender, but not always. Take an A4 sheet of thick card (the back card off an A4 refill pad is good for this) and push it backward through the paper path. Start where the paper normaly comes out and feed the card backward throught hte exit rollers, and on toward the main feed rollers. Don't go too far to the right side (wear the head "parks") as the paper sensor could get broken off. Persuade the card through the rollers and gently tease it in in out. Tip the machine on its back again so anything dislodged is encourage to come out. Work the card in and out GENTLY taking care not to exert too much force. If nothing falls out, you may have to dismatle the machine to get to the ASF to manually remove the oblect. If you intend to dismantle the machine, get a manual from http://TheServiceManualShop.com to make sure you do it right without breaking anything.
Nov 14, 2006 | Epson Stylus CX6400 All-In-One InkJet...
Canon Pixma iP2600 Photo InkJet Printer Logo
376 people viewed this question
old marine
old marine
