Question about GE WPGT9360EPL Top Load Washer
Whdsr315daww washer wont spin unless manually helped. New motor did not fix the problem
    Problem Solver:
  • 9 Answers
Please have the belt checked by a technician. It may be loose or exhausted.
Posted on Jul 22, 2009
The spin cycle om my Maytag washing machine isn't working, what can I do?
unless you know how to replace the transmission on it I would look for a new one
Mar 27, 2015 | Maytag Neptune MAH5500B Front Load Washer
GE WHDSR315DAWW Washer. The drum spins. The water drains. Agitator will not agitate. Help.
Normally the sign of a failed transmission - last time I bothered to buy one it was >$130 without service charge.
Feb 27, 2011 | Washing Machines
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
GE WHDSR315DAWW NEW MOTOR AND TIMER.WONT SPIN
only 3 things: drum is binding, belt slipping or motor too weak
Jul 30, 2009 | Washing Machines
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
SPIN CYCLE WON'T START UNLESS DRUM IS MANUALLY STARTED
YOU NEED A NEW COUPLING THAT GOES BETWEEN THE MOTOR AND THE TRANSMISSION...IT'S ABOUT A $20 PART.
Mar 13, 2009 | Maytag PAV2300 Top Load Washer
Wont drain and wont spin
It sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.
If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Also check the motor drive coupler.
Mar 09, 2009 | Kenmore 44102 Front Load Washer
Washer wont spin
if the belt under the washer is intact then the transmission is bad. generally its time for a new washer unless its still under warranty
Nov 22, 2007 | Magic Chef CAV2000 Top Load Washer
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Solution is right ...its your MCU Easy repair.
~Baloo
May 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washer wont spin
sounds like the motor or clutch unit could be the problem I would for sure call in the warrente shop to fix it as if its the motor thats expensive!! good luck
Apr 29, 2006 | LG WM-1832C Front Load Washer
GE WPGT9360EPL Top Load Washer Logo
217 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
