Question about Honeywell Heat/Cool Thermostat
Thermostat set at 74, but air conditioner won't turnoff
I have my thermostat set at 74, but the air conditioner won't shutoff until it's below 70. Many times I have to manually shut it off? It would run for an hour or more. Does my Honeywell Thermostat need recaliberated?
    Sergeant:
  • 384 Answers
Need to reset the lever sensitivitie( behind the cover) to a lower setting.
Posted on Jul 22, 2009
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
We set it at a temreture of 70 degrees but it wont go of when it gets really warm in my house does that mean that the termostat is old or what ????
Does the temp on the thermostat ever get to 70? As long as its at least 2 degrees below it will keep running, until it gets to the value you set. To test place a thermometer on top of the stat and compare the temp to its readout, if its still accurate it should be within 2 degrees of the reading. Keep in mind the location of the stat affects it (away from drafts, etc.) as well as making sure its vent holes are clean and clear, has good batteries and the area around it has nice unobstructed air flow.
Mar 08, 2015 | Emerson 1F80-0261 Blue 2" Thermostat,...
My thermostat show 74 degrees as a current room temp...but we have it set at 70 and it's probably 65 in the house. ..the only way it will turn on is if I put it 74 or 75????
The old white-rogers thermostats with a mercury switch are adjustable. snap the face off. In the center you will find a plastic slot screw. set the indicator to the actual room temp.
Other type ? Replace the thermostat
Mar 01, 2015 | Heating & Cooling
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
Thermostat will not go below 74 previously would go to temp set.
Once it shuts down it will stay off for about five minutes to protect the compressor...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 08, 2010 | Sharp AF-S125MX Thru-Wall/Window Air...
Installed the Honeywell RTH2300
at the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
Feb 14, 2010 | Heating & Cooling
Honeywell th8000 I can not set the cool setting any lower than 70, I thought it was supposed to go down to 40
There should be a way to set the parameters on the thermostat to go down below 70. Check your manual for instructions
Jul 28, 2009 | Heating & Cooling
My carrier unit will not shutoff runs conitnuously until early morning hour.had it looked at and has plenty of coolant and clean air filter.thermostat is set for 73 and will fluxuate from 74 to 75 will not...
what about the condenser. it needs to be cleaned too..
please check the condenser..it could be just dirty.
i hope i was able to solve ur problem..
pls rate me..
tnx
drcool
Jul 23, 2008 | Carrier Heating & Cooling
Honeywell Heat/Cool Thermostat Logo
244 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Dan Webster
Dan Webster
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
