Question about Refrigerators
Where the water comes into the freezer part of theice maker
Where the water comes into the freezer part of the ice maker it keeps running .dose not shut off once the trays are full.
  • charles farrow May 11, 2010
    see if ice maker is stuck on by seeing it rotate continuly with out stopping after water comes out. possiable ice maker replacement, or water inlet valve
  • Refrigerators Master
  • 4,654 Answers
Really sound to me that the water control valve is defective and will not close. Pull refrigerator away from wall and on the water control side for the ice maker disconnect the two wires. If the water continues to flow the valve is stuck open and will need to be replaced. Let me know, Sea Breeze
Posted on Jul 22, 2009
My Emerson ice maker, will make the 1st round of 9 ice cubes, then it fills back up with water and makes a clicking noise and won't freeze anymore cubes I'm so sad, I don't have money to buy a...
If it won't freeze the cubes that because the freezer section is not cold enough to freeze them. the ice maker itself dose not have any cooling in it. it all comes from the freezer. sounds to me like there may be a problem with the ice maker and it may need to be replaced.
Aug 05, 2013 | Refrigerators
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ice maker not making ice. There is no jam and all swithes are in the on position. I think a hose has disconnected, where can I find the hose to check it
Icemaker not working: Check the shutoff arm, the shutoffarm fails to move upward when the ice bucket is full. Check the water pressure. If thereis not enough pressure, the ice maker will not have enough water to make ice.Ifwater flow pressure is good, check solenoid valve activate and also it'scleaned. Locate your ice maker, remove theice bucket. Pull the cover off the end of the ice maker. Locate the holes "V"and "L". Take a paper clip (jump clip) and tape. Straight the clip and put tapein middle. Hold the taped side and insert the clip into "V" and "L". This sendsthe power to water valve. If water goes into ice-maker, water valve is good. Ifnotreplace solenoid. Check thefreezer temperature. The proper freezer temperature should be around 5 degrees.The warmer it is in the freezer, the more difficult it is to make ice. thanks,helpful?
Mar 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Theice maker in my refrigerator makes thin shallow
that indicates it is not getting enough water inthe ice mold most icemakers have a water adjustment screw behind the cover if it cant be adjusted the inlet valve may need replacing
Jan 17, 2010 | Frigidaire PLHS67EGSB Stainless Steel Side...
Ice maker water keeps running
Please keep in mind that I am attempting to diagnose a problem with your appliance without being there and with very little information.
My first guess is you will need to replace the water valve. How fast is the water coming out. If it's a trickle, you have a bad water valve. If it is flowing as hard as it flows when the ice maker calls for water,
there could be a problem with the switch inside you ice maker is bad and continues send a signal to the valve to keep sending water. You can check this by unplugging the ice maker from inside the freezer and if the water valve stops sending water. You will need to replace the part inside the ice maker or replace the whole ice maker.
Please rate solution
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Tube dispensing water into ice maker seems out of place
defroose the ice to the plastic white tube and the hole then pull out the tube, then the first end of the tube cut the end like an angle like to make it sharp but only one side then put it back, make sure the tube shoot to hole inside or more better if u remove all the 5 screws and check if in the right way then put all the screws back, ok what out with the small tube if connected properly or loose ok
Jul 29, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
I have a whirlpool gold refrigderator model# GS6NBEXRL00 and the ice maker is not producing any water. I replaced the whole ice maker and nothing happened. After unpluging and plugging the fridge back in...
you p robably have a frozen fill tube for the icemaker. coming inot the rear is a tube for dispensing water into the icemaker. check this for ice if it is frozen you can thaw it out by using a blow dryer to melt theice out. on some models this tube comes thru the back wall of the freezer for cross the freezer icemakers there is a black tube that comes out of the ceiling. if you have any questions please post here and I'll get back to ya thanks Peyton
Mar 06, 2009 | Whirlpool ED2FHEXN Side by Side...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice maker not making ice. I have .344 ohms at the solenoid.
your inlet water valve on the back of the frig. has failed and needs to be replaced-mike
Nov 08, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Roper refer/freezer with ice maker
If the ice maker is not running and water still comes in replace the solenoid valve where the water line attaches, otherwise replace the ice maker module
Jun 04, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
