Question about Beko 24 in. D3421F Free-standing Dishwasher
Problem - not work properly
My dishwasher model- D5323 FW-44I put the salt and powder , adjust the dgree which i want and push the play , it work for a moment and swich off automatically please answer .
  • 417 Answers
Sound that the control selector if faulty try a different program if the same thing happens then the control board faulty and will need replacing
Thanks J
Posted on Feb 16, 2008
Tip
What to do if your Dishwasher isn't cleaning well...
Check the following when experiencing poor cleaning results:
- Dispenser (Where you put the Dishwasher Tablet or Powder)
Make sure that the flap holding the powder in is not loose.
Make sure it is dry before ever putting in powder.
- Dispenser (Flap Type)
To check if it is still opening for the Spray Arms (Spray Arms need to throw water on the Powdered contents to wash the dishes) - Put the Dishwasher in a cycle, and halfway through the cycle, open the door. if it has not opened then maybe the solenoid/actuator needs to be replaced.
- Program Selector (Not the component, the function selected)
More time consuming programs are more likely to wash more effectively, try selecting these with a higher heat setting instead of your usual programs like quick wash etc..
- Machine overloaded.
Make sure the baskets are not overloaded with dishes, mugs & glasses as this can make spray arms find it more difficult to clean between them
- Soap
In tests regarding powder vs. 3 in 1 tablets like "finish", it has been shown that powder gets dissolved much better, this is because the 3 in 1 tablets are designed to disintegrate on certain heating phases of only a select few brands of Dishwashers. So if you are unsure, or experiencing undissolved tablet - Use powdered dishwasher soap instead.
- Salt container
Refill the Salt container every 3 - 4 months depending on how frequent you use the dishwasher
- Spray arms
These can often be clogged with dirty water etc. clean these with toothpicks and pressured water.
- Filter
Clean these every time after a wash, usually found at the bottom of the dishwasher where water drains away.
- Over the counter products
These can be bought at Appliance spare outlets or even at some supermarkets. Use these as the directions indicate.
- Element (Last step if not improved)
Replacing a element is usually a last option, if no improvement was experienced by doing all of the above it could be that the element is not heating at the right temperature, or not heating at all.
Either replace this yourself (with various degrees of difficulty depending to the Make and model) or get a qualified service technician to do it with you.
Hope this helps :-)
If you found this helpful, please vote accordingly.
on May 10, 2011 | Dishwashers
Where can I put the salt no compartment for it
Do you mean the dishwashing powder? You can drop the tablets or measured powder into the bottom of the dishwasher. Try adding 1/4 cup of vinegar to the long wash cycle to maintain a clean dishwasher and make the dishes sparkle.
Mar 05, 2015 | Dishwashers
Salt light won't go out in a Miele Dishwasher
As per other thread, descale machine with kettle descaler in the dispenser instead of powder, then run the machine through a cycle with nothing in the dispenser. The salt chamber sensor will eventually clear, but make sure you don't overfill with salt.
Apr 22, 2012 | Miele Dishwashers
Dishwasher powder
Check inlet water quality. It's hardness level. Use salt meant for dish washers. There will be a salt fill compartment. Refer user guide.
Finally check whether the rinse aid dispenser has liquid for dispensing.
May 26, 2010 | Dishwashers
After a complete cycle now have a milky residue
The milky residue on the glasses is not a residue at all: it is irreversible damage to the glass and is caused by a myriad of microscopic cracks in the glass surface combined with surface etching. Vinegar only works if there's a limescale deposit caused by using too little salt (no salt at all, or the salt dispenser set too low, or just not adding supplementary salt in a hard water area when using dishwasher powders with an in-built salt function)
It can happen to most glassware, but will happen very quickly to lead crystal which is why every single dishwasher I've ever sold or rented out says not to put them in the dishwasher. So called "glass protection" dishwasher powders are a marketing gimmick; all they do is to try and eliminate chlorides from the mix and boost the salt content, but they won't actually stop the damage completely.
Similarly, most advise against putting silverware in the dishwasher. By silverware I specifically mean anything made of silver, plated with silver or electroplated nickel silver (EPNS). Stainless steel is fine though. You might like to read this short article on the subject.
Mar 11, 2010 | Dishwashers
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
I put powder detergent in salt compartment in my dishwasher by mistake. What do I do next?
Just flush it out by pouring plenty of water into the receptacle. You don't have to get every last trace out. Make sure to wear rubber gloves and possibly eye protection as the powder is caustic and so you need to avoid skin and eye splashes.
You could alternatively leave the salt chamber cap off and run the dishwasher empty for a couple of cycles; that will allow the powder to dissolve without any chance of you getting splashes on your skin.
Nov 13, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Eurotech Dishwasher problem
Why did you put salt in your dishwasher?
Jun 09, 2017 | EuroTech EDW242C Dishwasher
Beko 24 in. D3421F Free-standing Dishwasher Logo
154 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
