Question about Motorola Mobility MOTOROKR Z6 Cell Phone
I need to remaove the front face cover so that I can fix the broken screws
  • 1,555 Answers
Its difficult, How shall I explain it to you. Your proper gateway to a path is broken through which you can open the other door which opens inside out. You are asking a way for a pathway for opening the second door from outside to inside. The only way is break it.
Posted on Jul 22, 2009
The front top cover over the face of the R-1611 is broken
The service manuals you'll need to refer to are here and here.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 09, 2013 | Sharp Microwave Ovens
I have a Hotpoint WDF740 washer dryer. When I turn the dial it doesn't register any cycle it doesn't make any noise when the dial is turned, therefore I can't use the machine at all. Can this...
This just happened to my hotpoint washing machine, I realise it has been a long time since this has been asked but since my answer is different from the others I thought I'd add it anyway in the hope it will be useful to someone one day. The fix was super easy, all that was wrong was the plastic knob itself, which had broken internally. I only found this out after taking the top and front covers off, which is an easy enough procedure, I did it this way: unplugged the washing machine, removed two screws from back of machine that hold top cover in place, then using a putty knife pushed between the top and front covers front to back right at the corners, thus releasing the top cover, once this was out I could unclip the front cover and get to the screws that hold the control board to the front cover. I unplugged the electrical connection to the board, removed all the screws and unclipped it from its plastic cover. At this point I could see the plastic knob had broken, I recovered the broken bit and glued it back on. After the glue dried, I just put everything back in place reverting the previous actions. Hope this helps. If you don't have glue or can't find the broken piece, you should be able to just buy another plastic knob off the internet.
Jul 06, 2011 | Hotpoint Aquarius WD640 Front Load...
Disk wont eject for ps3
If it's a fat system you'll have to have Sony fix it: 1 800 345 7669
If it's a slim:
1)
With the front of the console facing towards you, carefully turn the console over so that the reverse side is now facing upwards. Locate the HDD screw cover
2)
Lift and remove the HDD screw cover and insert a cross headed screwdriver into the location on the right.
The screw on the left holds the HDD in place. This should not be opened if attempting to eject a disk.
3) Once the corresponding groove is found, turn the screwdriver anti-clockwise (see below) to begin the release mechanism. The disk will slowly be ejected:
4) Remove the disk and replace the HDD screw cover.
Apr 30, 2011 | Sony Playstation 3 (PS3) Console
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
How do I open the case on a CTX desktop computer? All I see are the screws for the power supply.
Check the front face plate and you should be able to pull off the face plate and the screws should be located behind that.
Sep 12, 2009 | Computers & Internet
I have the pro 2050 radio shack scanner and the back light is out. Is there a way to fix it?
1 pull knobs off
2 remove case
3 looking at front pcb remove screws to front face cover
4 carefully remove front fase cover
5 look at LCD there are to small lamps on sides
6 replace lamps
7 replace cover
8 put screws back in
9 put case cover back on
10 put knobs back on
Jun 14, 2009 | Radio Communications
How to remove plastic front wheel drive cover on Toro Recycler
On my Toro recycler, I also had the front drive stop working -- and fixed it after reading the solutions here.
First, the plastic cover on the top deck that goes over the front drive mechanism must be loosened enough to pull it up. Before you can do that, on the underside there is one screw to take out.
Once that's done, all you have to do is pry the plastic cover up enough to see the belt and pulley that make up the front drive assembly. On mine, the belt had simply come off the pulley. Putting the belt back on, then tightening things back up is all it took to put the Toro back in sel-propelled happiness. Good luck!
Mar 07, 2009 | Toro Garden
Timer switch has broken on bosch wvf 2401 how to replace?
First remove screws X2 from back of the machine that hold the top cover on. Once removed the whole top slides backwards and can then be lifted off. This gives you access to the plastic clips that hold the timer face panel on. The main control dial must first be pulled off through the front cover, then remove the front cover by unclipping it (a pain and a fiddle!) The dial on the timer can then be pulled off revealing the two mounting screws that hold the timer in!!
Feb 02, 2009 | Bosch Classixx WVF 2402 Front Load...
How can I get the case of my Singer Featherweight II open?
To remove the cover of the Singer model 117 Featherweight II sewing machine:
Referring to the diagram below:
1.Remove the face plate by removing the single screw fastening it to the left end of the chassis.
2.
To make things easier, remove the presser foot (raise the presser foot and release the presser foot from its holder by pressing the black plastic foot release found at the rear of the foot holder, the foot will fall off.)
3.Remove the plastic see-thru slide plate that covers the bobbin. Remove the bobbin, and remove the two screws that secure the needle plate.Lift off the needle plate.Don't mess with the feed dog screws( Look closely at the" bobbin case assembly" and note how it is installed. The black thing you are looking at is the assembly. The chrome thing that looks like a hook is a fixed "bobbin case stop plate" , the case assembly fits under that and is supported by the hook race. Approximately 180 degrees from the fixed stop is a spring stop- note that the bobbin case assembly is free to rotate/ wiggle approximately 1/8" between these two points, and it is seated evenly in the hook race.Remember what you see so you can reinstall it later)Remove the bobbin case assembly with your fingers.
4.Remove the detachable tool case from the front of the machine by sliding it to the left.
5.The face cover is fastened to the chassis with four screws- two on the bottom which also pass through the bottom of the rear cover, one behind the face plate just above the lower thread guide, and one on the front of the machine behind the tool case. Remove the screws on the front and the left end, and loosen the two screws on the bottom ( if you are planning to remove the rear cover go ahead and remove the bottom screws completely.) There is no need to remove the screws that hold the auxiliary leg bar.
6.The screws are out- HOW DO I GET THE COVER OFF!?!
There is a hidden locking tab located just beneath the mylar seal that warns you to disconnect the machine before servicing and to close the cover before operating the machine. It is located just to the right of the needle plate and directly over the seam that separates the front and back covers. Don't remove the seal just slice it with a razor blade or utility knife right along the seam, make sure you cut all the way through the seal.
Working from the needle plate opening, take a medium sized flat-bladed screw driver and slide it under the rear cover just behind the seam (see photo) carefully twist the blade in a manner that both separates and lifts the rear cover off the front cover- it takes quite a bit of force and it will let loose with a loud snap. After the locking tab is loose the front cover is easily separated and lifted off the chassis.
unlocking the case:
a closeup of the tab on the front cover
7.The rear cover is held on by three screws. There is one through the back at the handle recess, and there are two screws accessible from the front after the front cover is removed. Lower the presser foot lever, pull the screws and the rear cover will come off easy. Good luck with your repairs.
Nov 10, 2008 | Singer Featherweight II 117
Removal of front cover
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
Aug 26, 2008 | Philips 190B6CB/27 19" LCD
Motorola Mobility MOTOROKR Z6 Cell Phone Logo
74 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
