1994 Pontiac Trans Sport engine stalled when backing up. It will not go forward. At the same time the automatic windows, interior fan and heater quit working. The scan says that there is a problem with the crankshaft sensor. Sensor is ok and ignition module and coils were replaced recently. Any ideas? Should I replace the ECM?
Hi there
Sorry, you have accidentally placed this in the computer motherboards category.
Regards
Posted on Jul 22, 2009
How do I time a 1994 Pontiac transport
    Pontiac Trans Sport firing order diagram spark plug wires ...
    www.fixya.com > ... > Cars & Trucks > Pontiac
    Pontiac Trans Sport cars & trucks firing order diagram spark plug wires questions and answers. ... 1994 pontiac transport se not firing in first coil pack at idle. images for 1994 Pontiac transport timing sequence
Oct 14, 2015 | Pontiac Cars & Trucks
I NEED A DIAGRAM OF SPARK PLUG TO COIL FOR A 1994 PONTIAC TRANS SPORT SE
Hi there:
1994 Pontiac Trans Sport 3.8 liter V-6 VIN "L"
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Oct 26, 2012 | 1994 Pontiac Trans Sport
Engine gets to operating temp. and just quits.. oil pressure good new fuel pump and checked complete fuel system ..when it cools down again it starts..3.8
causes are: low coolant, failing coolant temperature sensor, air in water pump, failed radiator fan, kinked heater hose. it takes 10 to 15 minutes to reach normal range.
Jun 08, 2011 | 1994 Pontiac Trans Sport
I need timing chain diagram for Pontiac trans sport. 1994 - 2,3 - 4 cylenders, Europe model. Can I find it on the web?
I'm not sure about the European model part, but maybe try autozone.com, joining their site, and searching under the U.S. models which may or may not have the same engine sizes.
Jan 28, 2011 | 1994 Pontiac Trans Sport
Where is the blower motor on a 1994 pontiac trans sport SE?
It is located under the hood just above the engine on the back firewall. it is hard to miss. look like a small coffee can stick out of the wall. it will have to thicker wires connected to it. (please rate)
Dec 21, 2010 | 1994 Pontiac Trans Sport
Front heater blower motor not working
The fan motor may have to be replaced, but I had the same problem and found that the wires connected to the fan motor were loose. The fan motor is behind the engine on the fire wall. Also check your fuses in the glove box. If you do have to change out the motor it's not hard to do, just hard to get at.
Sep 30, 2009 | 1994 Pontiac Trans Sport
1004 pontiac transport power windows do not work
sometimes the driver door window switch can cause problem. Pull door panel and check for power at regulator when pushing window switch. Door wire harness can also play a part in this problem too.
Jun 21, 2009 | 1994 Pontiac Trans Sport
Some thing in the wiring seems bad.
check the power wire at the starter selonid
Mar 01, 2009 | 1995 Pontiac Trans Sport
Pontiac Trans Sport
yes, it should bolt up fine
Jun 26, 2008 | 1993 Pontiac Trans Sport
Computers & Internet Logo
David Payne
David Payne
