Question about Microsoft Wireless Laser Mouse 6000 v2.0
Batteries last about 2 days. Indicator light
Batteries last about 2 days. Indicator light remains off. Must I remove tranceiver to save batteries?
  • timbrophy Jul 22, 2009
    That Does. Thank you. To be clear; if I do not remove and put in slot, is two day battery life normal? Thank you
    Brigadier General:
  • 7,191 Answers
To extend the battery life you must remove the receiver from your computer and snap it back in the slot provided on the under-surface of the mouse.
Hope this solves your problem Thanks.
Posted on Jul 22, 2009
  • AliTech110
    AliTech110 Jul 22, 2009
    The battery should last upto six months under normal usage conditions.
    Thanks
I canot get the tranceiver top transmit. When you push the traansmit button it justs beeps once. Signed Randy
This can sometimes be the sign of a low or bad battery. Try swapping your battery with a known good unit and see if the problem persists. If you do find swapping batteries solves the problem, then you will need to troubleshoot if it is the battery or the charger which needs attention. Clean your contacts on the battery and charger with a pencil eraser to ensure good contact, and always have the radio turned off when charging. Batteries typically last approx. 18-24 months before needing replaced.
Sep 07, 2015 | Kenwood KNB-15AM,...
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
Unit charges shows full and by mid day in a nursing home battery lights show only 2 red lights. do i need to replace batteries. the chair is a jet3 it was bought in 2003 and not used for about 2...
You definitely need new batteries. There are 2 size U-1 batteries in the chair that will last between 1.5 and 2 years. Get the deep cycle sealed gel lead acid batteries, preferably AGM. Hope this helps.
Feb 15, 2011 | Jet 3 Ultra Power Chair
I have the cobra CXT275 they have been on the desktop charger for 5 days. They won't charge over a 1/4 of the way how do I get the maximum charge?
Just went to their site and this is what it said:
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Jan 12, 2011 | Cobra Two Way Radio
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
Battery indicator reads empty when batteries are fully charged
It looks like your question was cut short... all I see is "Battery indicator reads empty when batteries are..."
With my experience with the Pentax *ist DL, I think the problem is probably that brand new batteries still show "empty" on the indicator.
Chances are that you are not using the CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
Neither lasted anywhere near as long as the CR-V3 batteries! While you may be paying $15-$20 for two CR-V3 batteries, they last a LONG time!
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500+) instead of $10-$15 ($2-$7 for film + $8 dev/print) for every 24-36 photos!
May 29, 2010 | Pentax *ist DL Digital Camera
Panasonic toughbook cf-48 two batteries went bad within a day
Place battery in freezer for 2 hours / remove and recharge, might make it last longer. (Removes any "memory" in them)
Might be worth checking the charger to ensure its working OK. Just becuase the light is on doesn't always mean its working.
Mar 10, 2010 | Panasonic Toughbook CF-51 Notebook
Unit will not work
has to have batteries,
Jul 24, 2009 | Kitchen Appliances - Others
Alarm function ats 909
To cancel the alarm press the "C" button. "C" equals cancel. You need to be in the set alarm mode for this to work.
Dec 21, 2007 | Sangean ATS 909 AM/FM/SW Radio
Microsoft Wireless Laser Mouse 6000 v2.0  Logo
206 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
