MAxtor One Touch External Hardwrive: I have a one touch. The light comes on and the drive tries to engage. You can hear it (spinning quick and then soft) then it just stops. Is this a power issue?
  • draykyn2 May 11, 2010
    This issue could be related to a connection inside the enclosure or the enclosure is faulty. Does it do the same thing when it is plugged into a different usb port or computer? It could also be a software issue where the computer is trying to assign the drive a drive letter (D, E, ect.) and the letter is already used (so the drive is not showing up on the computer). If you suspect it's faulty and it is possibly under warranty i would check the status of the warranty for replacement. If it is not under warranty (or you have data on there that you need and dont care about warr.) the best solution would be to take the drive out of the enclosure and plug it into the computer mobo directly; w/the computer off of course. If you aren't familiar with computer hardware i wouldn't recommend you do it yourself since any static charge or bump (drop) of the hard drive could cause loss of data. a local computer repair place could take it out and copy all of the data off the drive or get you a new enclosure (if the drive is ok, which they could also test for)
    Problem Solver:
  • 10 Answers
This is a test of the fan speed similar to a laptop or pc starting up.
Posted on Jul 22, 2009
When I plug my Maxtor One Touch III into a USB drive, the computer does not recognize it. Why? The light on the One Touch button flashes when it is plugged into the computer. Also, the computer...
Do you hear the drive spinning up correctly? It should be a smooth sound with possibly a few ticks at first and then a steady humming sound. If you do not? No sound? Check the power supply: connected - check voltage with voltmeter if in doubt. Strange sounds or noisy sounds and then silence? The hard drive has failed. New drive? Check the Disk Management console in Windows and verify that the drive is partitioned and formatted instead of just empty unallocated space (the whole bar will be grey instead of navy in Disk Management). To access right-click "(My) Computer" > Manage. Select Disk Management from the left pane. If problem persists, check the "Device Manager" from the same window for devices with Yellow Exclamation marks. Try reconnected or reseating the cables.
Apr 14, 2011 | Maxtor OneTouch III Mini Edition 120GB...
My Mac OS X doesn't recognize my Maxtor One Touch
Try unplugging both the power and data cables from both the computer and the hard drive. Let the hard drive spin down. Plug the cables back in. It should become visible with no loss of files.
Nov 07, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
My Maxtor one touch external hard drive will not switch on
HI,
The maxtor one touch hardrives generally have a 3 year warranty on them. If you have the orginal invoice for the same, I would suggest you to call maxtor and they can help you out on the same. The support information is available on the site below
http://www.maxtor.com/en/main/support.html
Best of luck
Proton
Apr 22, 2009 | E-Machines eMachines Desktop PC
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one touch
Does it sound like this:
Mar 23, 2008 | Maxtor Hard Drive
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
HELP
FORMAT WITH DOS ... FAT 32 .. YOU WILL FIND IT WORKING
AND FOR FDISK .. WRITE COMMAND FDISK /MBR
THIS WOULD RESTORE THE MBR.
Dec 02, 2007 | Maxtor One Touch III 500GB FireWire/USB2.0...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
