Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
The plastic base part snapped off during moving. Would like to replace, looks ugly.
  • 30 Answers
In most cases thats not worth repairing, but you should beable to order the parts from vancebaldwin. com
Posted on Jul 22, 2009
How do I get the plastic base off my singer 368, I have removed the screw and washer but the machine will not come away from the base
Take a look to see if you can locate a slot in the case that is wide enough to put a screwdriver in. Singer often does that so that after removing the screws, you can then pry the case off. In other words, the case also has a snap or snaps in addition to the screws.
Mar 30, 2017 | Singer Sewing Machines
Change doors from left to right
Depending on the brand, this "may" be possible. Look for a mounting bracket area on the side you want to change to. Is so, have someone help you, two person job!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Refrigerators
My monitor stuck down and i cant move it up the display solutions
You can remove the base and also see if debris is lodged between the back plane and the swivel head on the base. If you look carefully the cover snaps in place with plastic tabs. Once this is removed you can extract the screws that hold the base on.
Sep 25, 2010 | Samsung T220HD LCD Monitor
1987 ford f150 need to change both headlight assemblies
CAUTION The headlamp bulb contains high pressure halogen gas. The bulb may shatter if scratched or dropped! Hold the bulb by its plastic base only. If you touch the glass portion with your fingers, or if any dirt or oily deposits are found on the glass, it must be wiped clean with an alcohol soaked paper towel. Even the oil from your skin will cause the bulb to burn out prematurely due to hot-spotting.
Fig. 1: Headlamp components (click for zoom)
  1. Make sure that the headlight switch is OFF.
  2. Raise the hood and find the bulb base protruding from the back of the headlamp assembly
  3. Disconnect the wiring by grasping the connector and snapping it rearward firmly.
  4. Rotate the bulb retaining ring counterclockwise (rear view) about 1 / 8 turn and slide it off the bulb base. Don't lose it; it's re-usable.
  5. Carefully pull the bulb straight out of the headlamp assembly. Don't rotate it during removal.
WARNING Don't remove the old bulb until you are ready to immediately replace it! Leaving the headlamp assembly open, without a bulb, will allow foreign matter such as water, dirt, leaves, oil, etc. to enter the housing. This type of contamination will cut down on the amount and direction of light emitted, and eventually cause premature blow-out of the bulb.
To install:
  1. With the flat side of the bulb base facing upward, insert it into the headlamp assembly. You may have to turn the bulb slightly to align the locating tabs. Once aligned, push the bulb firmly into place until the bulb base contacts the mounting flange in the socket.
  2. Place the retaining ring over the bulb base, against the mounting flange and rotate it clockwise to lock it. It should lock against a definite stop when fully engaged.
  3. Snap the electrical connector into place. A definite snap will be felt.
  4. Turn the headlights on and check that everything works properly.
Hope helps, (remember rated this).
Aug 10, 2010 | 1987 Ford F 150
I get a 6a00 error, the first time i start up my canon pixma mx850. I tried to move the printerhead manually and that works fine. But i still get this error everytime. When I look at the sliding mechanism...
if it's 6A00 then theres a problem with the cleaning unit where the printhead parks. Look for any paper scraps in that area,
the two foam pads that must cover/protect the heads when the cartridge is parked are jammed up, preventing the head cleaning squeegee from moving back and forth. Just to the right of these pads is a piece of blue plastic, part of the assembly holding the foam pads . very gentle downward pressure on this blue plastic frees the pads and the squeegee could move back and forth again. and will clear ur issue
there is a safety pin lodged under the far right side (home base). gently push the unit to the left to expose the imposter, and remove it
regards
Aug 16, 2009 | Canon PIXMA MX850 Multifunction Printer
The 'feet' my piano stands on broke during a move
Try www.yamaha24x7.com/yamahaoms/
Jun 20, 2009 | Music
Need instructions to replace the bezel on a gateway 7330gz
Just like any other laptop LCD screen, edtechservic. Remove the rubber caps that cover the Philips head screws, remove the screws, and work around the bezel to pop it loose, a little at a time.
Top cover up, you are looking at the LCD screen. Look at the top Left and Right corners of the screen bezel. Look in-between. Now look along the bottom of the screen bezel. See those small rubber caps? G-E-N-T-L-Y pry them loose with a 60 or 90 degree pick. (In your computer repair kit)
Use care, and finesse! You don't want to scratch the clients laptop!
Now loosen, and remove the screws underneath.
Use a Jewelers flat tip screwdriver, (No.2), and ease it in the parting line, that you will see between the bezel, and top cover. Don't go more than a 1/4 inch in! You could be up against the LCD screen metal frame, if you go too far in. (Which could break the LCD screen)
Won't ease in there? Move over an inch or so. You could be hitting the plastic part of the bezel, that snaps down into the Top Cover.
There are several of these plastic protrusions, that stick down from the bezel, and snap into place in the Top Cover. Every few inches or so.
After you start easing one of these plastic snaps out, (Plastic protrusion I spoke of above), move along the edge, pick another place, and start easing it up. Keep bringing the edge up a little at a time. (Bring the back of the flat tip jewelers screwdriver down)
When you have gone along, and raised a large portion of the bezel, you should hear a distinct Click, as one of the plastic snaps come out of the Top Cover.
If not, move back to the first plastic snap that started to come out, and place your flat tip Jewelers screwdriver next to it. Bring the back of the screwdriver down to pop that plastic snap up, and out.
Hearing it your first time might make you a little stomach sick. You'll think you broke something! If you go along, and raise the bezel up a little at a time, you'll be okay. The bezel is made of space age plastic, and is VERY tough! You can't get crazy with it though!
When you have gone almost all the way around the bezel, the last few inches may just pop up, and out.
This link shows you with photos, and information, for a Gateway MT6704 Notebook PC,
http://www.insidemylaptop.com/remove-lcd-screen-from-gateway-mt6704-model-ma7/
This guide is to completely replace the LCD screen. You can just use the information under the first five photos, for bezel replacement.
Nov 15, 2008 | Acer Aspire 3000 Notebook
Replacing Passenger Window Motor
Hello, I have a 2004 Avl. I replaced the driver door window mechanism myself. You need to pry out the electric window controls with a dull blade as to not tear the vinyl. Disconnect the controls carefully. There are small release clips that hold the switch buttons onto the electric base. Then the arm rest, there is a long screw under the armrest. At the front towards the mirror there is a long screw under a round plastic snap cover. I believe it is a small metric bolt. Next grasp the bottom end of the door cover and pull with a sharp snap. Continue around the door panel gently pulling the snaps loose from their base. The door panel cover does not cantain screws only snaps. There is a clear plastic water barrior you need to be careful to peel without tearing and place on a clean flat surface with sticky side up. I had to replace the window track and motor all in one piece, can't just replace track. I purchaces the mechanism on-line parts store.
Aug 29, 2008 | 2003 Chevrolet Avalanche
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
