Question about AudioCodes MediaPack MP-114 FXS and FXO Analog / Digital Phone Line Converter
Hi, Here's my issue: a) I have a remote shed with no telephone/extension lines. I do have power and network access. b) I instaled a Polycom 301 phone at the shed. c) I instaled an AudioCodes MP-114 FXO in the house. d) A POTS is connected to the MP-114. I'm configuring the "Tel to IP Routing" tables to Destination Address 10.1.10.30 which is the Polycom phone's address e) A call comes in and the MP-114 tries to establish the connection but it doesn't go through. I'm seeing "SIP/2.0 405 Method Not Allowed" in the MP-114 log. Ideas?
  • danatcare Jul 22, 2009
    Thanks, but you'll have to be a little bit more specific.
    Are you asking me a question? Are you giving me an answer? Should I change configuration?
  • danatcare Jul 23, 2009
    Sorry wiz, I don't understand a word of you are saying.
  • 2,359 Answers
THIS is my recommendation. THIS IS FOR USA only.
THINK outside of the box!
1) Used Ethernet over power line boxes like Netgear.
http://www.netgear.com/Products/PowerlineNetworking/PowerlineEthernetAdapters.aspx
2) Find a working OLD PIII or P4 pc and set the ip to the same subnet.
3) Buy a MagicJack for $39.99
magicjack.com
4) Do the standard setup
5) connect Polycom 301 phone and use it.
Magicjack is SIP and it's $39.99 for package with 1 year service and $20 for the following year....
Posted on Jul 23, 2009
  • Vincent_G
    Vincent_G Jul 25, 2009
    From your home pc or laptop,please ping 10.1.10.30
    and look for any packet lost.
    Make sure the Ethernet and the power wires are NOT running side by side next to the power line.
    Make sure the Ethernet wire is under 100 meters / 328 feet
    Use a switch instead of a hub
    Try the setup closest to the hub first before you put it in service in the remote shed.
    I still think my magicjack recommendation will be more cost effective.
    My calculation is base on $19.99 per year all you can use local and long distance calls
    How much is your SIPS charging you per call?
  • Vincent_G
    Vincent_G Jul 27, 2009
    Are you able to check on the possibility of duplicate IP address?
    Even on a small network,it's possible to have two or more DHCP server/router/linux server give out IP addresses.
    Please append more information on the comment box.
    I will follow up on it.
    President:
  • 1,734 Answers
It seems like you are missing two Service Point Triggers in iFC IMSM in HSS (or similar).
Could you please check how many SPT's you have configured? It should be 17.
In case you have 15, please add two more and provision these as follows:
SPT_16
trigger when condition is true
group 5
Trigger type SIP Method
Method SUBSCRIBE
SPT_17
group 5
Trigger type Header
Name Event
Parameters contain
auid=org.openmobilealliance.deferred-list
Click Save button and try to register again.
    Top Expert:
  • AudioCodes Master
  • 79,851 Answers
Maybe the signal is to weak for lock on.
Posted on Jul 22, 2009
Polycom spectralink 6020 voicemail
All depends what phone system the Spectra runs along side with, call your vendor who installed it or your office manager/admin
Nov 17, 2012 | Polycom SpectraLink 6020 Wireless...
How do I change the current extension on my polycom 301 phone from 334 to 300?
Go to support on the new phones manufacturers web site and you can download an owners manual, which will tell you how to re-program the phones extension. murf427
Aug 01, 2012 | Polycom IP 301 SIP IP Phone
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
Mar 28, 2011 | Polycom SOUNDPOINT IP 301 SIP
Message light keeps flashing, but no message- Polycom 550
This is usually a problem with the phone's configuration. Is this phone getting it's configuration from a network server or pbx? If so, find the configuration file for your specific extension and find this location. This example is for a phone whose extension is 2704
msg.mwi.2.subscribe=""
msg.mwi.2.callBackMode="registration" msg.mwi.2.callBack="" msg.mwi.3.subscribe="" msg.mwi.3.callBackMode="registration" msg.mwi.3.callBack="" msg.mwi.4.subscribe="" msg.mwi.4.callBackMode="registration" msg.mwi.4.callBack="" msg.mwi.5.subscribe="" msg.mwi.5.callBackMode="registration" msg.mwi.5.callBack="" msg.mwi.6.subscribe="" msg.mwi.6.callBackMode="registration" msg.mwi.6.callBack=""/>
If you are not using a network-based configuration, the phone's settings can be changed via the phone's internal web server. Open a web browser window and enter the phones' IP address, i.e. http://192.168.1.109. The default user is 'Polycom' and the pass '456'. Go to the links at the top for each line you are using and scroll to the bottom, you will see the voicemail settings there. Use the above info to fill in the correct info, save the settings and the phone will reboot.
Feb 23, 2011 | Polycom IP 550 IP Phone
How do i conferance call on a polycom voicestation 300
The conference call feature is not part of the phone, but part of your telephone network. In some systems you press a sequence of keys to conference in another member such as flash #02 but it depends on what telephone network you use. Contact your IT admin and ask how to trigger the feature on that analog line.
May 14, 2010 | Polycom VoiceStation 300 (220017910001)...
Polycom Sound station - help it won't work!
what line have you connected to the polycom? you will need to connect a single line circuit line.
Apr 06, 2009 | Polycom SoundStation
MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Dec 09, 2008 | Polycom SoundPoint Pro SE-225 Corded Phone
301 Power Problem
you might have a grounding issue or electrical power. dish receivers need a specific amount of volts, what you can do is take an extension cord n connect it to the rcvr and take the other end of the extension cord n plug it in on another outlet in another ROOM, then see if it powers on , if it does something is wrong w/ the outlet even if u have A tv or other appliace plugged in, if it doesnt turn on then call dish network n get replacement receiver
May 13, 2008 | DISH Network 301 DTV Receiver
Noise on the recieving line
1-change telephone cable from your machine to wall outlet if the problem fixed it is ok,if not you must contact your phone company because noise may be in telephone line itself.
Feb 18, 2008 | Polycom SoundStation
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
AudioCodes MediaPack MP-114 FXS and FXO Analog / Digital Phone Line Converter  Logo
491 people viewed this question
Top AudioCodes Computers & Internet Experts
Mick Bowen
Mick Bowen
Level 1 Expert
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
