SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
SOURCE: Kyocera FS-3900DN Ecosys Call Service 2200:0100998
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
SOURCE: error llama 7410 0013444 impresora kyocera ecosys
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Cleaning the Printer
To avoid print quality problems, the interior of the printer must be
cleaned with every toner container replacement.
1 Open the top cover and MP tray.
2 Lift the developer unit together with the toner container out of the
printer.
3 Use a lint free cloth to clean dust and dirt away from the registration
roller (metal).
4 Insert the developer unit together with the toner container, back into
the machine.
5 Close the top cover and MP tray.
6 Open the left cover. Use a lint free cloth to clean dust and dirt away
from the vents.
7 Close the left cover.
8 Use a lint free cloth to clean dust and dirt away from the vent on the
right side of the machine.
I hope this is helpful,
Shawn
