Question about Northstar 951XD GPS Receiver
The DGPS doesn't seem to pick up a usable signal. After message of "init or synch" I get "Poor Beascon DOPS", it then may read "in Use-OK" for a few seconds and goes back to "Poor Beacoon DOPS". I have two units and I swapped them and get the same messages for both. The 8410ACU was replaced last year. The unit was not experiemcing this problem until now, ran fine for several months.
  • reelken Jul 22, 2009
    I can't take it out of the dock. I can't imagione it to be simple interference, as the unit has operated for many years in the same place.
    Many years ago I would temporarily lose the signal if the boat battery was not fully charged. I wonder if this could be the probalem now, though I initially ruled this out because I received the message while the boat was underway, and I assume at 4000rpm the battery is getting ample current.
    I called Northstar Tech direct. It turns out that the Gov't added another satellite that is incompatible with pre-2003 GPS software, causing various bugs. I was able to download a software update directly from their web-site that appears to have remedied the problem.
    I appreciate your effort and realize that only a OEM Tech would recognize the fix. I am relaying this info to you in case you have a similar problem in the future ( we all need to learn from each other).
    I will accept your effort so you can be paid.
    Thanks,
    President:
  • 2,777 Answers
Wow that is very peculiar. Can you take the GPS out of its dock and try it in different locations? It definitely sounds like interference, that's the only possible explanation since you have tried two units with the same results. Either that or the incredibly unlikely scenario where both units had failing internal antennas.
Posted on Jul 22, 2009
  • Tim Grayson
    Tim Grayson Jul 22, 2009
    Yes that definitely sounds like the machine is getting enough current, there's no way a power cable is loose underneath? You could try it on another battery but I know that would be a pain. The only possible explanations are interference which it sounds like is unlikely since it hasnt moved (nothing new has been installed around it has it, that could be causing new interference?) or a wiring issue that somehow the wiring is corroding and power's not getting there or the connections are loose.
    Let me know what you think
    Thanks
    Tim
What is DGPS?
DGPS stands for Differential Global Positioning System. DGPS achieves enhanced accuracy since the reference and user receivers both experience common errors that can be removed by the user. Position errors less than 10 meters are typically realized.
Feb 06, 2013 | Home Security
Nuvi 200w will not pick up sattalites
Make sure you are outside and as much in the open as possible. Staying stationary is the best way to insure a satellite signal. Give your GPS a few minutes if necessary to pick up a satellite signal. Also remember poor weather can effect a satellite signal reaching your GPS, just like it will satellite TV.
Mar 08, 2011 | Garmin nuvi 200W GPS Receiver
Frequently switches from dgps to gps fix .Why is this?
DGPS only works in areas where there is a DGPS beacon, and they're simply not that commonplace. Unlike orbiting GPS satellites, DGPS beacons are fixed land based devices.
When there's no DGPS beacon, the unit automatically reverts to the regular and slightly less accurate GPS.
May 19, 2010 | Northstar Explorer 550 GPS Receiver
Alternative to Leica Laser Locator
Leica locator with DGPS capabilities? Leica still manufactor advanced military systems under the Swiss brand name of Vectronix which is part of the Leica group. Are you after a laser locator or a rangefinder such as the discontinued 7x42 Geovid. The Geovid is still available but no longer has the electronic compass. The original never did connect to a DGPS PC only the Leica Vectronix Vector could. None of these models will locate a laser only use a laser to calculate distance. Current Geovids range to 1200 meters and the Vectronix 21 will range to 12 Kilometers. Unless you are a certified government customer the Vectronix 21 you will not be able to purchase. Newcon have models that allegedy exceed 2000 meters that are made in Russia and depending on the model can be had for a few thousand dollars. The Leica Geovid 8, 10 or 15 power can be had for around 2.5 thousand to 3 thousand dollars and is an excellent robust unit. It will not connect to a PC for GPS sync though.
Mar 12, 2009 | Leica Laser Locator Binocular
HELP ME WITH MY PALM CENTRO
I am having the same problem.
Aug 25, 2008 | Palm Treo 500 Centro
Using a DGPS on a 76csx
there is no possibility to use DGPS with 76csx... due to the fact that 76csx receivers use chipset the 'sirf star III' series and this chipsets don't allow use any RTCM data.
regards,
frankie, poland.
Feb 02, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Wont read disc-error message HO7
check out this link I think this information will help you. http://www.ledcar.com/pdvdh07/
Sep 17, 2006 | Panasonic DVD-CV47 Multi-disc DVD Player
Northstar 951XD GPS Receiver Logo
55 people viewed this question
Top Northstar GPS Experts
Are you a Northstar GPS Expert? Answer questions, earn points and help others
