Question about Dryers
Fan only runs in reverse. there is not a switch to change direction
    Top Expert:
  • Dryers Master
  • 78,267 Answers
Yes there should be a small switch up on the fan body above the fan blades
Posted on Jul 22, 2009
Chief Leun ceiling fan 54-OR somehow changed directions. No reverse switch on fan how do I change it
Every fan has a reverse switch, it is on the barrel of the fan above the blades. small black switch, down is normal up is reverse rotation.
Jul 01, 2017 | Dryers
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
I am working on an antique fan and for some reason when i fiinhshed, the fan was running backward? What did I do?
Some ceiling fans have a switch mounted on the fan itself for changing the direction of spin of the blades. Look up at the fan and you might see a switch on it which you can change.
Aug 31, 2011 | Emerson Dryers
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
HAVE AN EMERSON FAN WITH REMOTE ONLY THAT I CANNOT CHANGE DIRECTI
First, tell us the model of the fan as well as the receiver and remote?
Can not solve a answer without a thorough question...But I am willing to help.
Apr 08, 2010 | Emerson Fans Emerson SW375 Receiver
How do I reverse the blades without a remote?
theres a black switch around the fan to change directions , thanks AJ
Jul 14, 2009 | Dryers
Reverse ceiling fan
are you sure theres not a switch on the fan body ,, up/down= summer / winter...There should be
Jul 04, 2009 | Craftmade International (LC52EB) Ceiling...
How do you reverse the direction on this model of ceiling fan
I have this exact model, and have been so disappointed with the answers everyone has been giving about things they don't know. On the top of the fan, about one inch away from the center cover plate (the plate that slides up and down for looks, that is around the down shaft) run your hand around about two fingers wide, you will find a switch, RECESSED into the housing (if you are not feeling very carefully you will think it is just a normal opening in the housing. This will fix your issue, Unless you remove the fan or your head is crammed against the ceiling, you will NOT see the switch.
May 03, 2009 | Dryers
HOW TO CHANGE DIRECTIONS OF BLADES ON HAMPTON BAY MODEL #70226
There is a switch on the side of the fan motor housing. Slide it the opposite way to reverse it. Make sure you wait until the fan comes to a complete stop to do so. Never reverse it while it is running, you could overload the motor and ruin it.
I believe they don't put the reversing switch on any remotes for that very reason.
Sep 15, 2008 | Universal Remote Control Hampton Bay...
Dryers Logo
99 people viewed this question
Top Dryers Experts
