Question about HP Color LaserJet 2600n Printer
All four cartridges stuck on the right side in CLJ 2600
The solution given has nothing to do with this problem. Its a mechanical problem, not "stuck paper". I was able to remove the cartridges with the help of a pockt knife, pushing the plasic parts aside which block each cartridge. Inserting the new cartridges again required the use of the knife to lift a plastic hook and then to push a plastic roller to the right to give way for the cartridre.
Any REAL suggestion what could be wrong?
    President:
  • HP Master
  • 1,996 Answers
Please review the instructions for changing cartidges on your printer here , here and here.
It may ease your mind to know there have been others reporting the same problem with your machine, (see here), but I haven't been able to locate any legitimate solutions.
Make sure the correct cartridges are installed. (see here)
I haven't worked on that model, but I'm guessing that maybe opening the door is supposed to disengage the impeding parts and that's not occurring?
Otherwise, call HP support and they may have some kind of experience with this issue.
Sorry I couldn't offer something more concrete...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 22, 2009
    Brigadier General:
  • 10,406 Answers
There should be a ribbon-cable that pushes/pulls the cartridges left/right. Is that cable broken? If not, is the cable still connected to the casing around the cartridge?
HP CLJ 5500
If you mean toner, you can probably do it, but most new printers have a memory chip on the cartridge which keeps track of toner. Adding toner will not change the count and the printer will ignore the new toner
Jan 04, 2014 | HP LaserJet 9500mfp Printer
Printer only prints on left hand side of paper. Toner cartridges have been checked and replaced the Cyan cartridge since it was leaking. I also replaced the fuser and I am still having the same problem.
Other than tec guy are not advisable to do this exercise :Corosol align distrubed,open the printer up to corosol mechanism check rotary swing shoft left and right gears, there are markings which was exatly matching with rotary right & left disc markings. If its distrubed print quality issue will comes.
You are facing the same complaint. Before opening the machine ensure that read carefully service manual hp clj 2820/2840.. Best of luck.
Sep 07, 2011 | HP LaserJet 2820 Printer
Hp laser jet cp3505 printing only black and white pages.not printing colour
Its mechanical mis alignment problem,remove main motor assm which is located right side,you will find out four gear wheels row enguaged with other gears.. Upper 1st gear drives the mono catridge, remain three ment for colour catridge drive. Open this mechanism & absorve that each gear having align markings marking.If this alignment got distrubed you will get quality issue. Its very easy to understand to match each gear, take help of service manual suits clj 3600,3800. Try it...if fails try it up to sucess.... Best of luck..Vinay.
Sep 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
When changing an ink cartridge on my i9900, the cartridge carrier suddenly began to move. Because the cartridge was only 1/2 half way out, the carrier got stuck for a second or so at the side of the slide...
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Jan 28, 2011 | Canon i9900 InkJet Photo Printer
HP 2600 cartridge stuck in the printer
This is most likely a broken part, It is probably the drive connection to the transfer belt.
It's fairly common for these to break, and the part is not available as a spare (unless you strip one from another printer).
Jan 29, 2010 | HP Color LaserJet 2600n Printer
HP 2600 Cartridge Jam on Right Side
If they are locked in on the right side, the cartridge drive(s) are not being retracted when the front door is opened. There will be a broken part, which is difficut to obtain, and requires a major stripdown of the printer to find and repalace.
It can be easier and MUCH quicker to replace the whole gear assembly on the right hand side of the printer. These ARE available, and can also be removed from another printer with other faults/damage which renders that one BER.
Jun 17, 2009 | HP Color LaserJet 2600n Printer
HP 2820 CLJ, ONLY PRINTS DOWN ONE SIDE
ok typical carousel misalignment
http://www.fixya.com/support/t400576-printing_right_side_only#SameProblemContinued
just take a big screwdriver and check for stuck cartridges
Nov 05, 2008 | HP LaserJet 2820 Printer
Disassembling q6002 cartridge
if the your printer are hp clj 2600 then open door and then you can easily remove all cartages one by one
Jul 13, 2008 | HP Color LaserJet 2600n Printer
HP CLJ 3000
your printer needs servicing
Apr 23, 2008 | HP LaserJet 3000n Printer
Hp 2820 prints only on right side of page
????????? ??????????? document viewer ÷?? ???????
Dec 07, 2007 | HP LaserJet 2820 Printer
HP Color LaserJet 2600n Printer Logo
166 people viewed this question
Seeker5211
Seeker5211
