Pc gone dead while runing something now dont start no beep nothing but the fans reving to max i cant stoped from the start stop buton i must unplug, no video signal to monitor also, check everything ram video card cmos batery it may be mobo or processor???? any answer please
  • cristian csy Jul 23, 2009
    thank you so much but how to press f8 if pc dont boot at all no beep from hd or mobo and monitor say no video signal dvd drive no open nothing work beside cpu fan and video card fan can you reply to this one more please
    thanks Gassun il try tomorrow if im not at work to make the video tell me are you in ireland b cause i can get some cold guiness for you if you re close ha ha thanks again i ll send you the image asap
  • 499 Answers
Well it sounds that u have downloaded somethin' which support a high load which ur PC doesn't support ( this program or game may harm ur PC ) cause it make it work more than its ability so u need to go to safe mode (by press and hold on Button F8 when start ur computer) then remove the latest software or game (which is too big as i thought) then try to restart ur PC if this not work u need to formate ur PC and install new windows but before u want to install any thing new (try to check the specification needed for this software or game - The minimum PC requirement then campare it with ur one it if it pass then install it otherwise don't install it.)
Posted on Jul 22, 2009
  • ghassun
    ghassun Jul 23, 2009
    hi again thank again too well plz tell me what is ur pc type and if u could record a video which illustrate all the problems so I can see the problem better and help u more then send it to me via email my email is ghassanalasmar@hotmail.com ok but as i told u plz record a video (good quality) when u turn ur pc on and also record ur pc exterior ok
    hope this will be better
  • ghassun
    ghassun Jul 24, 2009
    well I hope that i'am in irland , I'm in Jordan right now
Hp 625
A bit vague? Unplug, remove battery, leave battery out, plug in , push the on/off button. Describe what happens, fan spins? LED's blink? HDD spins up? Sound? Any thing on the screen?
May 26, 2013 | Computers & Internet
Continous beep sound from the mother board
make sure your cpu fan is runing and the psu fan is running if they are then it maybe your computer ram
Feb 28, 2013 | Dell OptiPlex 760 MT Desktop Computer
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
Jul 03, 2012 | Dell XPS 420 PC Desktop
Ceiling fan stoped working when pushed two butons of the remote control at the same time
The fan's main system control might have entered into it service mode. Contact the delaer from which the fan was bought.
May 01, 2012 | Casablanca Fan W-52 Remote Control
On start up, my Computer just beeps. 4 beeps 2 beeps 3 beeps 3 beeps, then nothing. I have not installed any new software or hardware.. Any clues on how to relove this?
You have a hardware device or memory module or a part that has gone bad maybe loose or just needs to be changed out. Most likely it will be a memory module or a keyboard or a USB device unplug any of those items then restart the computer and see if the beeping stops.
Also you can remove a memory stick one at a time to see if the beeping stops if it does then you have found your issue. Also unplug the computer from the wall socket and push the power button in for 2-3 seconds this resets the computer to load its defaults. Look for the issue one by one and with the power button pushed after you unplug from the wall and ground yourself by touching the case metal before you touch parts inside the computer. I use latex rubber gloves personally.
Replace and go from there. It is about isolating the problem now to stop the beeping. So give that a try it is nothing that you have done it is the computers method of letting you now something is not working that is all. Thanks for using FixYa! John
Apr 13, 2011 | Lenovo ThinkCentre M52 PC Desktop
When I start up my Fujitsu Amilo Si1520, the fan starts working and nothing else happens -- screen remains blank.
Do you hear any kind of beep?
If yes, there is something wrong with your graphic adapter. If there is no beep, your MB is most probably dead
Nov 18, 2009 | Fujitsu AMILO PC Laptops
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
monitor
keyboard
mouse
powersupply UNPLUGGED RIGHT NOW
cpu with heatsink and fan attached
ram
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Car won't start at all
hi sounds as if your batteries gone dead is this the first time it has done this and is the charging light going out either way you need to check the alternator is charging the batery and the battery charged up check fan belt yates210456
Oct 14, 2008 | 2000 Ford Focus
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
