Question about Toshiba Televison & Video
Toshiba TP48E90 - picture goes dim intermittently, then protection circuit activates, power lamp blinks. In Self Diagnosis mode, POWER cose is 024, andthe prompt QV01S is red. Need to know if this is easy/common fix or if set should be junked - and new digital set purchased. Please advise. Dickiemag@aol.com
  • dickiemag Jul 22, 2009
    Just want a second opinion, possibly exact meaning of POWER: 024 in self diagnosis mode.
  • dickiemag Jul 24, 2009
    Pretty much as I expected. Thanks!
Hi there
A blinking power lamp usually indicates a power fault within the unit. It could be due to a blown fuse but I am unable to locate specifics on the POWER code 024.
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact the Toshiba Customer Solutions Department at 1-800-631-3811 Monday through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station.
Best regards
nLinked
Posted on Jul 23, 2009
    President:
  • 2,777 Answers
Definitely sounds like one of three things, all of which are pretty expensive. The least expensive is that it could be a failing power supply, this will definitely blink the lights like you have described.
It could be also a failing lamp, after a while this will just happen, and it's pretty expensive.
The third is the logic board of the TV is failing, which can cause all kinds of problems and is very expensive.
Most likely you will want to replace the unit unless you think it may still be under warranty.
Hope this helps!
Tim
Posted on Jul 22, 2009
RED FLASH AND TV URNS OFF
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Original Link
Dec 06, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Have an eight flash after a no start condition
Sony Blink Codes Rear Projection Sets Report Email Written by RustyM62 on document.write(LocalTime.getShort('1241232540000')); May-1-09 7:49pm From: the-tv-dude.blogspot.com
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.This can be caused by bad picture tube may also see burnt components on the crt pcb.
Nine blinks - Replace D 6116 and D 6301 on the "G" board. Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning that sometimes the TV comes on and at other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12v or -13v.
Aug 11, 2011 | Sony KP-53HS30 53" Rear Projection...
Sony kv-13fs100 keeps on blinking four times when power button is pressed, no picture. have no cable.
Hi, below are Sony blinking codes are thier solutions...Hope it helped...
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.
Jul 09, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Standby light flashes green and red, the pattern is 11 flashes, is this serious
Submit the TV to an authorised SONY workshop for a quote and a full assessment of the actual problems. This repair could prove expensive/uneconomical, but it is up to you. The quote (and their second opinion) should help.
Here is a list of the problems that might have occurred indicated by the number of blinks:
* Unit is dead, No blinks = Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
* Continuous blink once a second, no pausing = No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
* 1 blink = not used for the self-diagnosis
* 2 blinks = B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
* 3 blinks = B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
* 4 blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
* 5 blinks = AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
* 6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
* 7 blinks = High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
* 8 blinks = Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
* 9 blinks = Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
* 10 blinks = Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
I assume the TV has no picture/sound as a result.
Dec 15, 2010 | Sony KV-36FS12 36" TV
Replaced bulb on sony KDF-42WE655, When power turns on then turns off with 3 flashs of red light continuouis?
SD Tech,
With your kind permission if I may provide info...
3 times red light blinking shows that lamp cover has not been fixed in its place securely after lamp replacement.
Make sure lamp cover, its the first plastic cover that was removed to replace lamp, is back in its position properly then turn On tv.
This plastic lamp cover engages safety micro switch inside tv cabinet.
Aug 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture and sound cuts off ,greem stb light keeps blinking TV turns on after 30 secs shuts off after 30 secs comes back on. Continious loop
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70&keyword2=electronics
Dec 28, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
No Picture, Sound Fine
Hey John, How many times does the light blink? No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. I suggest you do a hard reset. Unplug the power cord for 4 hours. Then plug it back in and check it. If it works, great. It not, cost of repair for this is usually around $150 - $250 plus the house call.
Jun 26, 2007 | Sony KV-27S36 27" TV
Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
