Question about GE WPGT9360EPL Top Load Washer
Washer wont spin unless maunually started
A new motor was put in and still doing the same thing. Looking for solutions here
  • 867 Answers
Depending on type, seems like the belt or clutch is slipping
Posted on Jul 22, 2009
SPEED QUEEB AWS17NW HOW DO I INCREASE SPIN SPEED IT SPINS WAY TO SLOW CLOTHES ARE STILL WET
Well could have a bad motor, and depends how much are you loading into it. Remember the more cloths you put in it and all that water collects in the cloths and weighs it down. Try a Smaller load! Unless this waster is a HE Washer it wont.
Sep 28, 2014 | Speed Queen AWS17NW Top Load Washer
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine works but when it comes time to spin it gets stuck the water drains but wont spin you can hear it trying but its like the brake is stuck if I open and close the lid then it will spin and...
Assuming that you have a Kenmore / Whirlpool top load, direct drive, neutral drain washer.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Also check the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 16Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, the kit cost us $15.00 which is a lot less than the $170 for a new transmission.
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Wiper fluid wont come out
Yes there is a fuse so check that first, either under the hood or under the dashboard (there maybe more than one).
If the fuse is good continue, if not replace.
The next thing you should do is (with an assistant) probe the connector for the windshield washer (while someone is trying to activate it)
If you have power to the washer pump then replace the washer pump, if not then you will have to take it in, unless you are good at troubleshooting electrical problems.
Jan 06, 2010 | 1995 Pontiac Grand Prix
SPIN CYCLE WON'T START UNLESS DRUM IS MANUALLY STARTED
YOU NEED A NEW COUPLING THAT GOES BETWEEN THE MOTOR AND THE TRANSMISSION...IT'S ABOUT A $20 PART.
Mar 13, 2009 | Maytag PAV2300 Top Load Washer
Wont drain and wont spin
It sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.
If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Also check the motor drive coupler.
Mar 09, 2009 | Kenmore 44102 Front Load Washer
Kenmore 92274800 repair ... WONT SPIN
My 110.92274800 did the same thing 1hr ago. Ive isolated the Problem it is a 15.49 cent problem from the manufacturer's website Part # 285753A. I am going to order and try and tackle the problem myself unless i can find it at a local Appliance Center that has it on Monday. Will keep you informed. Doesn't look to Hard. if you lean your Washer forward you will probably find 1/8 inch white peg looking plastic pieces. assuming you can hear the motor running on the spin cycle. You may lean the unit forward put it on spin and look at the motor to make sure it is still in operation. Hope this helps
Jan 03, 2009 | Kenmore Washing Machines
Washer wont spin
Is the lock door light on if not change the wax motor & the main control board (board is approx $169.00+).That is the problem unless the belt slipped off .Common neptune issue you have will most likely repeat itself so,you decide from there.
May 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Front load washer wont spin
Open the rear panel and look for a broken belt and does the motor spins. In case motor doesn't spin, check on its tags for 115/220V. Let me know with your results,for further assistance if will be needed. Good luck!
Aug 28, 2007 | Frigidaire ATF6000ES Front Load Washer
GE WPGT9360EPL Top Load Washer Logo
61 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
