My problem though is that I am not sure which way round I am supposed to be looking at the board when plugging the cables in. I have the following cables that are causing my problem:-
2 Pin Power Switch cable (Green & White)
2 Pin Reset Switch cable (Red & White)
2 Pin HDD LED cable (Black & Red)
Single Pin unmarked cable (Green)
Single Pin unmarked cable (Black)
so as you can see especially with the unmarked cables I am stuck. All I have connected is the power cable from the PSU to the Motherboard. Once I can connect the front panel connectors correctly then I will connect drives, PCI cards etc.
I had looked at that before but am confused. The case is made by Tiny, a company that I think is now defunct.
I think there may be another problem as I have installed the board, connected the 4-pin power cable to it from the PSU and the larger cable to it too. I have then connect the 2-pin Power Switch cable to the pins on the front panel connector and tested it without any drives or PCI cards installed (just to see if the system powers up), nothing.
I think it could be a board problem or PSU problem, strange really as both board and PSU were working perfectly a few days ago.
Thanks for getting back to me.
I'm stuck!!
Regards,
PaulThanks Tom,
i don't understand what you mean by the pins are Left side going up 2-4-6-8-10-12-14-16 Right side going up 1-3-5-7-9-11-13-15 #1 has no pin #2 is on the left of #1 i don't understand what you mean by the pins are Left side going up 2-4-6-8-10-12-14-16 Right side going up 1-3-5-7-9-11-13-15 #1 has no pin #2 is on the left of #1
You can't post conmments that contain an email address.
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will. Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide. Hopefully this information helps.
2. Just plug the front panel switch headers to the JFP1 main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will. Note:
Hi sivaprasanna,
Do you still have your manual? If so turn to page 72 for location.
For a close look at the motherboard front panel led to MB pins look at these two pics.
Location of front panel connections;
Item " A " is the front panel MB pins.
Pic two is the layout for each front panel connection;
The power on jumper uses pins 7 & 8.
Pin 7 is positive & pin 8 is negative.
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard. I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
The motherboard connection points to the front panel audio jacks are shown in the diagram below. It was cropped from a page of the user's manual.
A downloadable version of the English version of the User's manual is at http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf
Hope this be of help to you. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Thanks Tom,
I'm stuck!!
Regards,
Paul
the pins are
Left side going up
2-4-6-8-10-12-14-16
Right side going up
1-3-5-7-9-11-13-15
#1 has no pin
