Question about Kenmore Washing Machines
My kennmore washier machine spin cycle will not operate
The washier machine works in every cycle but the spin cycle. After the rinse cycle the machine cuts off.
    Problem Solver:
  • 16 Answers
Most likely the lid switch !!!
Posted on Jul 22, 2009
Why does a kennmore washing machine work during the final spin and the water input does not stop?
does it only final spin? would say bad water inlet valve but should do the same in wash cycle also??
Mar 07, 2015 | Washing Machines
I have an estate washier & it makes it too the rinse cycle & stops. Any ideas why?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Whirlpool Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Kennmore 110.22422. 100 hummms when reaching the spin cycle
your timmer button has given up replace the timmer and it will be fine
Jun 19, 2010 | Kenmore 22422 Top Load Washer
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Washer wont rinse,spin or drain
you might have a problem with the lid switch..there is a plunger on the bottom side of the lid, close to the front edge which operates the lid switch..if the switch is broken, it probably has become torn apart so, if you can identify the two wires that would've been on the switch, you can just twist them together, tape them and the machine will operate normally, until you can get the switch from Sears... because I have a service contract with Sears, I don't pay for the repair (twice) they normally charge dearly both for the part and labor..
Aug 14, 2009 | Washing Machines
Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
Apr 02, 2009 | Asko W6021 Front Load Washer
Lent on clothes
Not familiar with this model but it sounds like too little water is being used (small, medium, large load) or a rinse cycle is being skipped.
With enough water and normal rinse cycles, the lint should be suspended and pumped down the drain. If this is happening with every load, then it isn't working properly.
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
