Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Replacement Mitsubishi lamp busted again in less a year!
I have replaced the original lamp for my Mitsubishi DLP. The original lasted for about 4 or 5 years.
I am surprise that the replacement lamp did not last long!!
  • 668 Answers
A Halogen lamp is a Halogen lamp. They are designed to last between 3000 to 5000 hrs.
You got a much longer life than expected on
the original lamp.
Posted on Jul 25, 2009
Dlp blue screen
the lamp eng it bad you need to replace the dmd or the hole thing the eng, whear the lamp in stall at and i done a lot of them to and that cost a lot 1000.00 plus the core you need to send back to mitsubishi you may whant to call them to see if it under wearenty if not that will till you how much it cost to have it replace..it a big job it chang them to about 2hours to replace them the lamp eng ..good luck i hope this help you out...me my self don,t like a dlp at all the lamp cost to much to replace for lasting just a year. lamp should last about 2 years but i not seen a lamp last that long at all..the samsung is just as bad... will good luck
Nov 19, 2013 | Mitsubishi WD-52525 52" Rear Projection...
What is causing the lamp to keep going out on an 82" 837 Mitsubishi TV?
If a OEM Mitsubishi lamp was used you likely have a problem with the Ballast that drives or powers the lamp---the two pin socket for the lamp goes directly to the Ballast.
May 30, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Lamp light no pic
yes yes yes.the lamp needs replacement. you are very correct.that is the indication of lasmp replacement which your tv is signalling.replace it quickly.
howto replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
Mar 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Burning out lamps on my 65inch dlp
I have 65" Mits. lamp lasted about 2+ years and burned out. bought new on internet, that lasted about 5 months and went. Got free replacement and that lasted about 4 months. No more free replacements ...
Bought new from different source and it burned out in a week.
Note: These were ALL OSRAM original lamps from reputable suppliers.
They sent a new one but also cautioned about cleaning the "filter" on the lamp housing. NOT the large screens on either side, but the small rectangular one (about 3/4" x 2"). I did this with a shop vac pulling and pushing from every angle and it was really clogged almost solid. No way air was going across the bulb to cool it.
THIS IS CRUCIAL and I feel is the keys to the kingdom! I did this and voila - no more "plastic smell" when installing the new lamp and everything's great!
I feel that Mits should be held accountable for this for not recommending the lamp housing be cleaned periodically (maybe yearly). I really feel if this were done with my original one it would have last a lot longer.
Lou
Dec 14, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
