Question about Roper RGX4634KQ Gas Dryer
Roper gas dryer does not heat.
Roper heavey duty professional gas dryer does not heat. I repalced the ignitor and still no heat. The unit is pluged in and does operate, but does NOT produce any heat. There is gas up to the gas valve, but gas does not flow to the ignitor. Is there a procedure that has to be done before the ignitor heats and the gas flows?
Thanks for your help. Tom
  • 1 more comment
  • shipsheguy6 Jul 23, 2009
    No I do not see the ignitor glowing. Tom
  • Craig Butler
    Craig Butler May 11, 2010
    Do you see the glow of the ignitor heating up, but won't light? Does the ignitor not glow, more info for help please...??
  • Anonymous Mar 15, 2014
    STEP BY STEP INSTRUCTIONS HOW TO CHANGE IGNITOR
HOW DO I CHECK MY ROPER GAS DRYER IT DOSNT HEAT UP
Posted on Dec 12, 2010
    President:
  • 1,714 Answers
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Posted on Jul 23, 2009
Roper gas dryer has no no heat. not really sure of dryer #. but this is the basic set up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[
Mar 24, 2011 | Roper RGX4634KQ Gas Dryer
Dryer running ,but no heat.Roper gas dryer,mod - RGD440VQ0, Sn - MW/2901047
Most common reasons for a gas dryer to fail: 1. No electric, 2. no gas supply, 3. failed ignitor, 4. failed flame sensor. If 1 & 2 are ruled out, then we go from there. An ignitor/glow ignitor is what gets hot and allows the gas to be ignited. Most dryers will not let the igntior come on if the flame sensor is down. Replacing an ignitor is very easy. Usually 1 screw and a molex (special type of plastic electrical connection). Molex connection will usually pull apart very easily. This repair should cost less than about $30 if you buy it online. There are step by step instructions for this repair on this website if you search for "gas dryer no heat troubleshooting." Making this repair will require access to the internal workings of your dryer. Make sure the dryer is unpluged from the wall before you access it or the control panel.
Feb 05, 2011 | Roper Dryers
Roper gas dryer won't heat,even after installing a new inginter what else
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 19, 2011 | Roper RGX4634KQ Gas Dryer
Want heat roper heavy duty dryer
heatman101
Dec 14, 2010 | Roper REX4634KQ Electric Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
ROPER GAS DRYER WILL NOT BUT RUNS
heatman101
Aug 13, 2010 | Roper REX4634KQ Electric Dryer
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
Roper dryer gives off no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
jjk
Nov 24, 2009 | Roper RGX4634KQ Gas Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Roper RGX4634KQ Gas Dryer Logo
674 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
