Question about Canon imageRUNNER 5000 Copier
Our Canon ImageRunner 5000S shows the Error Code E000003-0000
The Error Code is E000003-0000 and I need to get it fixed ASAP! If anyone can help me, I would GREATLY appreciate it!
Thanks!
Danielle
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
This error is related to fixing unit,to reset error:* with head 2&8 together* with head LCD display change press COPIER> Function>Clear>Err>OK switch off/on the machine,if the error return check the AC supply unit or you have to call your service provider
Posted on Jul 22, 2009
Canon imagerunner shows error message when turned on: e000220-001
You can try to reset the error code in service mode, but the problem will need to be fixed before it will clear. Scanner lamp problem
Oct 19, 2012 | Canon imageRUNNER 2200
Hello, I have a Image Runner 5000s. It has an error message of E00000-0000. I have turn it off and on,but it only reboots half way before the error comes up again, then it shuts off shortly afterward....
this is error for thermistor fault, due to faulty thermistor or faulty temperature thank's to lamp or just temporary trouble wich can be reseted.
To reset:
While the error is showing before it shuts down:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * )
Choose: Copier>Function>Clear>error and ok
if needed turn te copier off and on.
If the error persist call service...
Hope that helps!
Sep 14, 2011 | Canon imageRUNNER 5000 Copier
IRC5185i Stopped working. Shows Error code
i looked to see if there was a user fix for this problem but there isn't. It sounds like the driver pcb board could be blown and or the fixing assembly needs replace.
Jun 05, 2010 | Canon imageRUNNER 5000 Copier
Imagerunner 5000s with an error code e000014-0000
this is fixing motor fault
you need to replace main power pcb, fixing motor or dc controller board
you can not reset this error
Mar 31, 2010 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
E000007-0000
this code is for damaged fixing film, on the end you have home position sensor for good position of fixing film.
Feb 04, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Error Code
E602-0003 try to recover you program turn OFF the machine when turn ON just hold 19 when the small box show just wait in few minutes until the screen tuning full white.... if the code is the same just contact SC near by you to reprogram machine
Jan 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
ImageRunner 5000s network printer Mulit-PDL kit
Hi shadetree. Just thought. Are you sure you got the "entire" kit which would have included an additional 64 meg of memory? I ask this since the network boot rom would require and expect to access additional boot data from the 64 meg of memory. I am not sure of the 5000 controller architecture but lacking the additional memory, the ir may lock up(no display) at the beginning of the boot sequence or as the most recent controller lock up as you see the machine boot.
Jan 01, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
1,242 people viewed this question
old marine
old marine
