Question about Garden
My petrrol tank seeps fuel around the welded seam of the outlet spigit . tank is maid of plastic
    Scholar:
  • 71 Answers
No good way to fix this..............sounds like you need a new one.
Posted on Jul 23, 2009
After a couple hours riding power dies after half throttle. if I shut machine off for 5 minutes it runs fine again. temperature runs between 130-140
Confirm that the tiny tiny hole on the gas cap vent is not plugged!!!
This is such a common failure and it has been know to crush the plastic fuel tanks. The pump pulls a vacuum on the tank and eventually the walls of the plastic tank are crushed opening up the seams of the welded plastic tank.
Of course the plugged vent doesn't matter after that since the fuel spills out from the fractures of the seams of the tank. No direct replacement tank available only one 1/2 the volume of the original. It takes a total disassemble to replace.
Feb 28, 2016 | ATVs
Gas leak on the seam of plastic gas tank
Looks like time for a new tank. There are methods for "welding plastic" you might take it to a Shop that repairs raditors and gas tanks. When you take it to the shop have as little gas in it as possible. SHOPS HATE IT WHEN THEY HAVE TO REMOVE 20 GALLONS OF GAS BEFORE REMOVING THE TANK. You might check with the dealer to see if this is a common problem if its not collision damage.
GOOD LUCK. PLEASE POST AND LET US KNOW WHAT YOU END UP DOING.
IT HELPS WHEN YOU ASK THESE QUESTIONS IF YOU TELL US THE MODEL AND YEAR OF THE CAR.
Mar 30, 2015 | Mercedes-Benz C-Class Cars & Trucks
What would give out fuel smell ?
did you check to see if your gas cap is missing?
Jul 13, 2014 | 2000 Ford Taurus
How to fix a leaky Toro 20007 fuel tank
If the fuel tank is metal take it off and clean the seam with sandpaper and use JB weld to repair it- If plastic tank, use a glue gun.
Apr 18, 2014 | Toro Lawn Mower With Toro Power Tools
8 gal losing air, checked all connections, no leaking, where else to check ?
look for a small leak around the welded seams on the tank as well as all the welds on fittings. When there is air in the tank, shoot some soapy water on it like you were looking for a leak in a tire to find small leaks.
Nov 11, 2013 | Campbell Hausfeld 8GAL Air Compressor
How to repair a plastic radiator tank on a 2004 vectra MOTOR HOME with 230 cat engine
you try using plastic epoxy something like link below
http://www.homedepot.com/buy/paint/adhesives-tape/0-85-fl-oz-plastic-epoxy-loctite-54207.html
make sure u drain radiator and lightly sand area on radiator to allow epoxy to stick better
Jun 10, 2012 | Cars & Trucks
Fuel smell when turning no leaks
I had an 88 Supra that had a leaking fuel tank, at the halfway point up on the tank, at the weld seam. It used to only leak either when I filled the tank up or made sharp turns. Seeing that your car is also a late 80's Toyota, have your fuel tank checked out.
Mar 03, 2011 | 1989 Toyota MR2
I have leak in plastic tank. This is on wheel barrel type 100000 BTU Reddy #2 fuel oil type. Leak at seam. Can I patch ?
Yes. Empty and clean all oil off throughly. JB weld will patch it up for you but you have to be sure it is clean and oil free.
Oct 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
What does diagnostic code PO455
A code p0455 most likely means one or more of the following has happened:
  • A loose or improperly affixed gas cap
  • A non-conforming gas cap (i.e. not factory/original brand)
  • Other leak or damaged piece in EVAP system
With a p0455, the most common repair is to:
  • Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
  • Otherwise, replace the gas cap, and/or
  • Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary.
Sep 29, 2009 | 2003 Hummer H2
Fuel tank leaking how to solve problem gas is not pouring out but is seeping through bottom of tank
I don't think you will have any luck sealing this from the outside.
Removing the tank (preferably empty), filling it with water and soldering all of the seams (if metal) or replacing it if of plastic.
This could be sloppy manufacturing showing up late, stress from being slammed underneath (is there signs of dents or scrapes?) or if metal, it might be rusting through which is pretty much a death sentence for it.
Pouring some (a cup or so) methanol, pure ethanol or a commercial product intended for that use, into your tank now and then will cause condensation to bond to the gasoline where it will pass though the system and out.
Aug 10, 2008 | Jeep Grand Cherokee Cars & Trucks
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
