Question about Pelco PCM100 Camera Mt CC/MC3700/3600 SERIES
My pelco DVR just show black & white?
When i connect my camera to DVR MUX card it give me b\w ,but when i connect it to the output in DVR give me color , by the way the camera is pal and the DVR software also pal but i don't got color, other problem is that my ipsxm30cbw23x camera it gives me black picture but when i enter camera setting i get the picture back?
SOURCE: I'm looking to hookup the DVR with the PC via A cross-over cable
I have 2 DX2000's, In order for you to communicate with your pc, you need a Crossover cable, if you have a laptop or computers, connect the crossover cable to that, set your ip address on your computer to 192.168.2.108, (Note: since you never configured it, this would be the default setting). If you have the manual this is in there.,
Another method, if you don't have a crossover cable is to set the ip on your computer to 192.168.2.110 Subnet, 255.255.255.0. its a little more funky, the crossover would be easier, once you get in, then go to the configuration page and setup up the IPaddess for the DX2000, the Gateway to your Router and the subnet mask, once you do this, then you're able to get to it on your network, by typing in http://xxx.xxx.xxx.xxx:8004 .
Posted on Mar 23, 2009
SOURCE: i have pelco dx 2000
yes, on the configuratiion plage, use the schedule to increase the amount of time you want for
1) Sechedule recording
2) motion recording
3) event recording.
Remember, this is all based on the size of your hard drive and the number of camera you have installed.
SOURCE: My pelco DVXe dvr display is at minimum not 32 bit cant see pics
boot into bios and set your display for vga mode. At least that worked for me
Posted on Jul 30, 2009
  • 5 Answers
SOURCE: I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Posted on Aug 10, 2009
  • 14 Answers
SOURCE: Problem setting up Network Cameras
on the cameras them self there should be a adress and baud rate setting this should be the same as what you have on the software. also the cable that you have going back to your ethernet panel cannot be by any electric lighting or anything like that and check and make sure that the connetors that plug in to the panel have the right color code. you need to look for the straight through wiring diagram 568b. hope this helps.
Posted on Mar 14, 2010
Why does my blackpoint tv show my cameras in black and white
you cant plug it into the component plugs as you see it is b&W...you need to plug it into the AVI input which may be on the side of your TV or even the front depending on the model
JA
Aug 09, 2014 | Televison & Video
Why does my color quad processor show images in black and white?
Without more information to go on I would say that it is in low light condition. If this is equipped with night vision that it records in black and white in low light situations. The recording feature on the DVR may also be the cause. Make sure you are set to record in color.
Jul 17, 2014 | Pelco Qd104c Color Quad Video Processor -...
I am looking for a wiring diagram for a Pelco TV10AC zoom lens.
Zoom yellow
Focus Green
Common Black
Common Red
video (aiv) AUTO IRIS lens back side
1 = Red wire VCC (+9 to +18 VDC) _____
4 = Black wire Ground p ' '
3 = White wire Video Signal L ' 2 1 '
u ' * * '
g ' '
1 = red ' 4 3 '
2 = nc ' * * '
3 = white \ /
4 = black \ /
\__/
Jan 04, 2011 | Pelco Cameras
I recently bought a DVR, a Pelco DX4000 Series. I have been trying to link this DVR to my laptop for my security cameras. It DOES connect; it's just not showing live video. It does show the live video on...
You need to install the Video drivers and enable the "Overlay" I suspect, you have not got the latest Video drivers for your card, go to the cards web site, ATI, NVIDIA etc, and download entire package and install.
Mar 08, 2010 | Televison & Video
On the monitor there is a small little camera
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is not coming from the camera...They don't put anything like that out. Check the OSD settings of the device the video is going into. If there is On Screen Display setting with in the device (DVR, MUX, Matrix Switch, ECT)....if that doesn’t work then check the monitor menu to see if its a display feature you can turn off...good luck and let me know if this helps just remember the pelco camera will not push any graphic out except in the case of a PTZ where you will see the Protocol information text...
Jul 09, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Apr 09, 2009 | Pelco Home Security
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
White screen
your camera is defetive, ask to the technical person who can check this
Aug 19, 2007 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Pelco PCM100 Camera Mt CC/MC3700/3600 SERIES Logo
57 people viewed this question
Top Pelco Computers & Internet Experts
David Payne
David Payne
Are you a Pelco Computer and Internet Expert? Answer questions, earn points and help others
