Question about Ingenico eN-Touch 1000 Digital Pen
Pen writes in one spot, but image shows up 1/2 below.....
Wondering if there is some type of calibration that can be done. The pen writes in one spot on the screen, but the actual text shows up about a 1/2 inch below. I have searched and come up with nothing so far.
  • 3 Answers
Re: Pen writes in one spot, but image shows up 1/2...
1. To calibrate the ENTouch 1000 power off the device.
2. Prior to restoring power touch the pen to the center of the screen and do not move it.
3. Power on the device. Leave pen in center of the screen and do not move it. If you move it the device will not enter calibration mode.
4. Allow device to boot. If you held the pen in place the EnTouch 1000 will enter calibration mode.
5. Follow the on screen instructions. Be very methodical and do not try to rush it...
Posted on Aug 08, 2008
0 characters
3 Points
No Calibration for Wacom Pen
Sounds like your pen has problems, after so many attempts to calibrate the pen fail your tablet will automatically shut that feature off. I would suggest getting a new pen if possible and recalibrate it. The wire or fiber optic cable, which ever it has is bad to break where it bends down into the pen. Also the sensor in the end of the pen could have gone bad. I would contact the manafacturer on it and see what their tech's advise.
Mar 07, 2014 | Wacom Cintiq 13HD 13.3" Interactive Pen...
Bamboo pen and touch is slow
you need to calibrate the display under settings
Jul 14, 2013 | Wacom CTH460 Bamboo Pen Touch ...
Can no longer calibrate my cintiq pen
i found a button that switches the pens location, it says display toggle in the wacom properties, idk when i click it it switches back to the right position try pressing all your buttons or put your settings to default and try the buttons
Nov 15, 2009 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Duel Monitor Cintiq Problem... pen affecting wrong monitor
under the calibrate tab in the wacom tablet properties window there is a drop down window with a list of monitors. Change that to the Cintiq
Jan 19, 2009 | Wacom Cintiq 15X Graphic Tablet
Wacom babmboo pen does not work
If the eraser part of your pen works but the business-end doesn't, this fix may be for you. Since the only option is to replace the whole pen, it's worth the try. The interesting part: There is no "live" powered electronics in the pen (it is a simple L-C circuit for you tech-weenies out there) - truly the only way to make the pen not work is to drop it and knock it out of adjustment, use it as a crude paper punch, or get it soaked with some type of fluid such as coffee, beer or soda. The pen is an excellent design is designed to just eventually wear out. My pen is 10 years old and still looks new.
I needed a small jeweler's screwdriver for this fix (1 mm to 1.2 mm width). Carefully remove the rocker switch from the pen; it just pulls out. Don't lose it. See the image below: there is an itsy bitsy slotted screw-like device in the center (it's a tuning capacitor). For its location, follow the white arrow in the picture I've attached. Prior to turning, memorize where the slot-head points (there's a tiny triangle on it), and if possible, use a fine point sharpie to mark the screw before you adjust it. It is not a "screw" per se, but an adjustable capacitor and part of the tuned circuit.
The adjustment: Place the pen as normal on the tablet and "tweak" the capacitor by a small 1/16 or 1/8 turn in either direction until the pen reacts. If it has gotten out of "resonance" this tweak should kick it back in.
Apr 17, 2008 | Wacom Intuos2
Bamboo fun pen feels ridged
I had the same problem with only the eraser working but I fixed mine though it was kind of risky... I had to disassemble the pen. I think this voids the warranty so, do it at your own risk. OK, so this is how I did it: 1) I first took off the tip and the eraser (only the cap, not the coil inside) using my teeth as suggested in here! 2) I pulled the two parts of the pen away in the middle *carefully and slowly* for about half a centimetre, then unhinged the blue plastic (not the one with the buttons, the one one the "rear" side) 3) When the rear slid off, I unhinged the "buttons" plastic and the whole circuit could come off easily. I noticed that the front coil had a broken core (the cylinder that holds the wire in place). I used super-glue and voila!!! Problem solved!
Jan 20, 2008 | Wacom (PTZ930AC) Graphic Tablet
Writing with the pen
I've done this, but only by using a graphics program, creating and saving the signature and then importing it into Word as an image and placing it where I wanted it...
Hope that helps a bit.
Oct 31, 2007 | Wacom Graphire4 4x5
Dispaly on eN-Touch 1000 is getting blank
Check the power adapter, sometimes they get hot and they don't supply enough power to the pin pad. Also make sure that the power cable is not loose, twisted or broken, this can also contribute to the problem.
Oct 22, 2007 | Ingenico eN-Touch 1000 Digital Pen
Ingenico eN-Touch 1000 Digital Pen Logo
637 people viewed this question
Top Ingenico Graphics Tablets Experts
Gareth Cockram
Gareth Cockram
Are you an Ingenico Graphics Tablet Expert? Answer questions, earn points and help others
