Question about U-Line Refrigerators
Uline under the counter two drawer refrig seems to be running very hot, with ER blinking on temp gauge inside top drawer
  • 286 Answers
Hi
Er means that somthing is wrong. It could be a temperature problem that caused it. Does it beep at all. That is a alarm for the door being open. You may need to check the magnet on the door and the reed switch on the wall. Upper left for the top drawer. and on the bottom is on the grill and door. Normally this is something I would ask for a tech to look at. But if you feel confident to try this I can get you into the program to see what its telling us. Now hold the up arrow and at the same time press and release the light bulb 3 times. Then release the up arrow last. If you did this right then you will have a 0 on the display. Yes, Then up arrow until you get to 3. Then press and release, It should give you a number. E# ? Let me know what this is. You may have a couple so write down all of them.
Now after you got the number then just push up arrow until you get to 99 then press and release the light bulb to go back to the refrigeration cycle.
E3= bottom drawer open to long
E10= Top drawer open
E1 = Thermistor #1 open
E5 = 10 degrees to warm E6 = 10 degrees too cold E7= Thermistor 2 E8=Thermistor 3 E9 =Thermistor 4 open thermistor 1 located top drawer Thermistor#2 I/M or evap if no icemaker
Thermistor3 is located in freezer or base if no freezer thermistor 4 is drain pan
Hope this helps
Posted on Jul 24, 2009
Temp gauge stuck past hot mark
The stepper motor that controls the gauge is bad , gm had problems with 03 to 06 vehicles . Here watch the video !
How to repair GM Instrument Cluster Speedometer Gauge Stepper
Apr 20, 2017 | Pontiac Aztek Cars & Trucks
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
What should the temp gauge in my 2005 911 C2S read in "normal" operation? The engine seems to start and run beautifully, but I have noticed that the temp gauge inside the car shows the engine warming up to...
they are designed not to fluctuate with engine temp and are kept stable once operating temp is reached. only if the temp exceeds a set mark will the needle rise to indicate overheating,
Aug 31, 2009 | 2009 Porsche 911
1996 Cutlass Supreme-Temp shows hot even after engine rebuilt
is the temp gauge sender new
or the engine cooling fans spinning fast enough
air in the heating pipes ? bleeding
Feb 28, 2017 | 1996 Oldsmobile Cutlass Supreme Coupe
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Leaking water
you need to remove the bottom drawer and check your drain in the back each time it goes into defrost it sounds like the water is running to the bottom of the unit instead of down the drain
May 19, 2008 | Amana Refrigerators
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
1,018 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
