Question about Dryers
Replacing dryer belt maytag gas mod.mdg9206bww
Hi
can you give me step by step instructions on replcing this belt,
    President:
  • 1,714 Answers
Here you go , watch the video:
Posted on Jul 22, 2009
Maytag Neptune mdg6400aww heats up for 1-2 mintutes then not heat
Make sure there are no major airflow obstructions. If not, replace the coil packs on the gas valve.
Aug 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer, model mdg9206bww, has lost power, replaced ignitor switch about 3 months ago, any suggestions where to start?
try checking the voltage commimg into the dryer outlet make sure you have 208/220/240 volts at the two hot terminals and 120 volts from ground to each of the hot terninals if only getting 120 to one terminal you have a bad breaker or fuse
Aug 23, 2009 | Dryers
Maytag dryer mdg9206bww runs but will nto get hot. Gas does not come on. Have volt meter and exp. working on electrical equipment but do not understand sequence and where should have voltage on settings.
This most likely has a "Glow Rod" type of igniter for the gas, along with a photosensitive glow/flame detector. Most glow rods are ceramic with an electrically conductive coating that makes them a resistive element. They will last until the ceramic breaks. Be careful with it, if it's not broken, it is very fragile, and so is the replacement.
Jul 06, 2009 | Maytag Dryers
Dryer won't shut off after cycle
i got to know what cycle you are using the timed dry or the auto cycle timed dry you may have a bad timer if auto dry it coult be the auto dry resistor or it could be a clogged vent.
Jan 19, 2009 | Maytag PYG2300A Gas Dryer
Drive belt needs replacing on Hotpoint TC71P
how do i get my tension correct on a hotpoint tc71p
Maytag electric dryer mod#DE612 series02
U might want to look on the back of the dryer to see if there is a panel to take off. If not the hole top will have to come off. Is the top made on the rest of the dryer or is there a split between it.
Nov 24, 2008 | Maytag HYG2460AWW Gas Dryer
Maytag Dryer
hi thanks for the question the belt has stretched replace the belt thanksthe appliancedoc
Sep 15, 2008 | Maytag SDG4606A Gas Dryer
Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
Jul 10, 2008 | Dryers
Dryers Logo
196 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
