Question about Dometic Rooftop RV Air Conditioner
I need a wire diagram to install new unit - Dometic Rooftop RV Air Conditioner
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
What unit what thermo stat do you have on wall
Posted on Aug 01, 2009
2 Suggested Answers
emissionwiz
  • 76164 Answers
SOURCE: Need wiring diagram for installing
we do not have any wiring diagrams for this unit, suggest u contact the manufacturer for a service and repair manual
Posted on Oct 07, 2010
My rv furnace want start up i changed ac units new don't have the relay box build in it how do i rewire the furnace ?
Shooting from the hip here, but look at both the new and old wiring diagrams. Chances are that the new unit has terminal leads that would connect to the old units' relay/control box and you simply need to install the old box on the new A/C by connecting to the correct terminals. beyond that, you can build your own relay setup if you understand wiring diagrams. If you don't know wiring, I'd recomend taking to an RV shop, as you can damage either the A/C or the furnace or both if wired incorrectly... Hope this helped!
Mar 26, 2013 | Heating & Cooling
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
Control Board burned out...how to install new one? Is it a DIY or does a professional need to do it?
Hello, you can replace it yourself if you are comfortable reading a wiring diagram and connecting wires. The best way to replace it is to sketch the old board on a piece of paper with all tne terminals and wires connevted to it, or just refer to the wiring diagram on the unit if it has one. Tjen take out old board and replace with new board and connect the wires.
Jul 07, 2011 | Heating & Cooling
Stereo wiring diagram for 91 rodeo
i you need is the wiring harnest from walmart, wire up the same colors on back of the head unit to the new harnest, then slap the new harnest to the factory harnest DONT CUT THE FACTORY HARNEST, WILL CAUSE YOU A BIG HEAD ACHE but crutchfield gives out free step by step diagrams
May 01, 2010 | Car Audio & Video
I need the schematics so i can install the thermestat
There should be a wiring diagram with the new thermostat you can follow.
If not,remove the control panel cover from the outside unit and follow the diagram printed on the inside of the cover.
If there is not a diagram there,remove the panel from the indoor unit and use the diagram printed there.
If not one there tell us what brand thermostat and what terminals are on it and we can tell you which wire goes where.
Mar 18, 2010 | Goodman CKL36AR36 Air Conditioner
I need a wiring diagram for a 2002 883 harley sportser
If you are going to install a new ignition unit, all you basically need to know is which wire is the "HOT" wire. Disconnect all the wires to the coil, turn the ignition switch on and use a test light to find the "power" wire. Once you know which wire this is, you'll need the wiring schematic for the particular type of ignition unit you're installing on your bike. Usually, if you got the website for the manufacturer, they'll have "installation instructions" under their "Technical" section. Usually, with a dual fire ignition system, there are only three wires to hook up. Good Luck!
Feb 22, 2010 | 2004 Harley Davidson XL 883 Sportster
FREE ONLINE DOWNLOADS OF WIRING DIAGRAMS
i ned my home hetr and ac wiring diagrams to thral contral
Sep 30, 2009 | 1998 Ford Explorer
CHANGED OUT UNIT NEED HELP NEW WIRE
Is this heat pump? Straight A/C? You should have a wiring diagram with a new unit (installation manual) that will give you what you need depending on your model. They generally have a few different configs so they only have to put one manual in every unit. If it's a straight a/c, its simple. You have two wires coming off the outdoor unit. One goes to the y terminal and the other goes to the c terminal. Y is for cool and C is for common. A heatpump is a lot more difficult and I would recommend hiring a professional to wire it up so you don't burn up the defrost board. Also, you may find a wiring diagram on the inside of the outdoor cover. Hopefully this helps.
Apr 09, 2009 | Goodman CLQ36AR49 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
126 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
